man i feel dumb being the only person spent more than 10 monutes on this damn thing
I go to push in and its hittin crap and no place for it to sink in or a slot for it
Did the stock trim piece have that "guide"? As I recall, it fit into a slot or something as a guide on mine. I did not cut anything on mine - it only took me 10 minutes to do this mod. Edited by chuckl1218
Yeah there is this packet with 5 pages of pictures... but its not really instructions idk what the hell its saying. I was also beyond frustrated so that didnt help
So what I did was: I aligned the Assist Handle Assembly with the pilar similar to the original trim. Then inserted the bottom edge "integral locator pin (x)" into the dash. Once this was positioned, the "integral clip (y)" would align to a slot in the pilar. Then I pressed the top of the Assist Handle Assembly toward the pilar. At this point, the bolt holes lined up, so I installed the bolts and bolt covers...done.
I hope this helps.
the problem was that point piece, i got everything else 75% of the way done. There just wasnt anywhere for that piece to go so its pressing against the frame. I pushed hard a cpl times but really didnt do anything.
The way you described is about what i did besides putting in the bolts. Im sure once im relaxed and less frustrated with it I can figure it out
That piece fit right into a circular hole which is BELOW the black airbag tether for the original thing. If you want a clean install with zero cutting, you have to pry the black tether out. It's hard, because it's tough, I had to stick a screwdriver below it and apply a lot of force. But if you do that, everything fits just dandy.
Added GMC caliper covers
Ron,
Like the covers. Where did you get them?
Thanks...
Also, I just finished installing an Airaid MIT. Looking forward to seeing if it makes a difference.
Edited by Hisdem
Ron,
Thanks...
I got them from carid.com. They have red and black ones. They have some engraved with GMC or Denali. Or you own custom message.
Keep us posted on that. I'm curious as well.
I don't know if it's really the MIT or my head messing with me, but it does feel a tad more alive I guess you could say. Seems like I don't have to push the throttle as far. Again it could just be my mind playing tricks on me. I still have the stock filter so I don't think it did much of anything.
I didn't buy it for performance anyways. I got it to make it easier to get to things and to clean up the engine bay.
I got it to see if I get an MPG increase. I've driven only 70 miles so far, so not enough to test that. But I have noticed that in regular acceleration, in the 1000-2700 RPM range that the engine sounds a LOT more like a V8 should. That smooth roar is now there.
Even if I don't see an improvement in mileage, the MIT was worth it just for that sound and how much easier it made it to access the engine bay.
The MPGs seems the same. As for the sound, it's hard for me to tell since I put the MIT on after getting the exhaust done and the exhaust is aggressive. I want to think it helped a tad with throttle response, but like I said, my mind could be playing tricks on me.
I'm hoping one day I can get some headers and a tune.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
