Line X today
I hope they removed the caps on the sides and front of the inner bed.
Just depends on if he plans to use them. They can be cut out. I have my tie downs on all 4 upper corners like his. I don't plan on using the ones in the front or middle of the bed.
I had them leave the top 4 corners. They offered to cut out any other ones I might ever want.
They weren't sure if the caps would still pop in after the line X was sprayed. So I just had them cover them.
Caps still work after Line-X.
​Finished swapping out headlights from 2wdmallcrawler and tow mirrors. Last one just for fun - man aint nothing beat football and fox season :thumbs:
7F262183-2427-4C0D-BB19-BBA33BD46DD7_zps
Got some new rubbers. It's a DD so nothing aggressive.
I see you have not bought the 10 dollar filler caps for those holes in the rear.....
where from?
Mine is a DD too, 100 miles a day for work which is why I wanted something with some lug to it. I'll pick up a new set of wheels for the OE tires come spring and then have summer and a winter set.
Thinking about getting these as a winter set of wheels and tires (if they fit lol) think they'll look halfway decent?? Thoughts??
    • Are we talking about the same thing, though? The 7 versus 3 wear metals was from Lakespeed's 3.0-specific oil brand comparison test between AcDelco oil and Mobil ESP. The filter remains a constant so whatever excess particles the AcDelco oil is producing aren't being filtered out.   I'm assuming there's a parallel comparison to be made; IF the filter can filter down those particles, engine life increases, and your graph makes the case that a better filter (lower micron rating) can increase engine life. Introducing fewer particles AND filtering those particles with higher efficiency is the best of all worlds. Good oil, good filter.   Where we may disagree is the "baseline relative engine life". I'm more apt to believe the base engine life value is 200k+ on very average oil and filters, "bulk oil of unknown brand and white-label generic fleet-grade filter, Jiffy Lube"   Going from a 10 micron filter to a 5 micron filter should boost a base 200k to 275k in a vacuum as a single factor alone.   Here's the whatabout: How does regularly changing the oil and filter ahead of recommended schedule influence baseline engine life? Most people aren't going to science the heck out of this stuff or ask about Micron ratings, HTHS, or wear comparison tests at Jiffy Lube. Most of the Jiffy lube techs would say they need to call their tech support line to even try to get an answer.   --   Because we love anecdotes here, when I was fishing for 4.3 parts at a local yard this weekend, ALL of the 4.3 vehicles had well over 200k. I love looking at odometers of junked vehicles. How far did THIS go before landing at the crusher? The ones that still had engines weren't seized. None of them were vehicles I'd consider were Amsoil queens, in fact most of them had some kind of service cling-sticker in the corner of the windshield indicating it probably had very average maintenance services. Even the fresh parts rigs- I'm not sure taking an S/T series to 400k has much value considering the running value of those vehicles was probably somewhere around $1,000. 25+ years is a good run on time alone.   The intake manifold I salvaged had clean and bright pool areas. As expected, I found the fuel lines in the manifold rubbed through, just like mine. I'm guessing the lines on that donor truck started leaking, the truck started running rough, and its owner said that's enough I'm unwilling or can't take it out of service for several days, or spend $1000+ to repair it at a shop, it's simply time for a newer more reliable vehicle (or, more than likely, this is the 2nd, 3rd time this has happened in the truck's lifetime). While I don't count on my Blazer for reliability, the thought of giving it away for parts at certain points during my adventure, and being mentally free from its needs has has crossed my mind. I'd be losing $1500 or so, but I can only make more money; not time.
    • still $4.00 85 oct.
    • Always here to help. Discount Code: TIFF5OFF
