1 hour ago, sk said:
Not sure what you mean "just like everyone elses".  I installed mine over 2 years ago and didn't have any problems.
Did you leave all the bolts loose until everything was hung then adjust everything?  I did that (per the instructions) and my gap is perfect the entire way across both sides.
If all 4 lights quit working then it sounds like you may have knicked the wire that controls the lights or there is a problem with the control module.  Did you contact AMP Research?  Their Tech Support and Customer Service is great so they should be able to talk you through troubleshooting then get you replacement parts if needed (the steps come with a 5 year warranty).
X2 mine has no gap and i installed them same as you
I will look and see,  out of town on business will check and take a picture when I get home
On 1/8/2018 at 2:14 PM, sk said:
So are you planning to share the link and info for the fogs?   :thumbs:
https://www.amazon.com/gp/product/B016O424B8/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
link to the amazon page! here is a picture of them installed hard to tell but they were snug fit for me! i did fill out the pre-check for the vehicle at the top as i didn't have a good part number besides H16. hope that helps!20171202_162710.thumb.jpg.a019def72e8bdc3522cbdce2e6b9fe01.jpg
On 1/9/2018 at 3:56 PM, lapoolboy said:
Do your lower linkage bracket bolts look the same as mine?
looks like it but mine has a washer 5a57ba8d483fc_bolt.thumb.jpg.44e6cdd7182464ad43470643243f25a2.jpg
That's my problem...they didn't send those washers in the package.  They have sent me some new bolts with those captive washers on them that look like yours.  That should solve my issue.
Got my VDP wheel well toolbox with the speaker in it yesterday. Next week’s project. Wish I cous this weekend but first trip for snowmobiling ??
Not my truck, but worked on a local member’s trucks last weekend. Added OEM Tow Mirrors with the Echomaster Intellihaul system. Front Camera, Left/Right Mirror Camera, and a Wireless Trailer Camera. Plug and Play. Pretty neat system if you Tow. Left/Right cameras automatically activate when you use the turn signal. Also did - Dual Function Running Lamps/Turn Signal mod.
  • Like 7
I've been looking at that system. Just don't know if it's a justifiable cost for a 1/2 ton. I don't even see the need for tow mirrors on my truck, even with the duster on the car trailer or my parents 20' travel trailer on the back, I can still see everything. It would be nice to have the wireless camera on the back of the trailer though, one that could be viewed on the factory HU.
This is my "dream" modification.  Does the total cost to the owner have 2,3 or 4 at the beginning of the 4 digit price?  ;-)  Nice work pgamboa, as usual!
How about a 3 digit # beginning with a 7? He had this system from a previous that got transferred over.
Here is a link on eBay for this kit. Shows to be $799. :). Doesn’t include the tow mirrors of course and any harnesses associated with a tow mirror swap.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F131917667572
Pulled my Kicker VSS System out to make room for a custom system. Listed on the marketplace.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
