Redid the tint on the back windows and rear window to limo
I had to ask. How would you and your passengers get into the truck? The floor must be at least 4' off the ground.
AMP steps [emoji106]
Sent from my iPhone 6+
I agree... looks better with the valance.
RT
But with a level or a lift, the skirt looks like the truck is doing a curtsy LOL
Tried adding some pics through tapatalk, i have no idea if it will work. Had a few minutes to snap some bad pictures. Debadged some of the chrome, rigid lights on n fab light bar, light bar behind the grill, added back up lights, dipped the rims.....more to come.
Sent from my SM-G900W8 using Tapatalk
No excuses, pictures or it didnt happen!! Lol.
Cant wait when you have the pictures up!!
Made the plunge...sold my 14 and am picking up my 15 today...pics soon!!! :driving:
What made you want to change? Upgraded trim or engine size?
Edited by Roidz
I upgraded for a few reasons. Firstly, our low Canadian dollar means that our used trucks go to your wonderful country for an increased dollar. Secondly, there are a lot of incentives and lo financing. Thirdly, I was off warranty, and lastly I was so ticked at my old seat it was time for a new one...
Whats wrong with the seat?
Glad to see another albertan on here!!
Prepare to be jealous, girls.
Hood mounted brackets for light pods.
Big thanks to the boys of Alternative Off Road in Cali, for the custom work and all it cost me was a bottle of fireball.
Note: still in the early stages and as it sits, I might have problems with the antenna interfering with the light pod. Details to follow.
Looks great but I need to see more of these. Was hoping to put mounts like this on. Let's see some pictures of the lights on the mounts also
Sent from my XT1080 using Tapatalk
Got my front windows tinted and put in some Weather Tech mats. Next up is a Roll-N-Lock A-series and Airaid MIT.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
