Got new rims and tires today. 22" XD Monsters on 285-50-22 Nitto Terra Grapplers G2
Edited by dbcooper748
  • Like 4
Added the basic tow mirrors this morning. I have to say it is a bigger pain in the rear to install these than it seems like it should be. Why stuff the wiring harness halfway down the door behind the door trim panels. Makes a quick easy task into much more work. But all went well in the end. I cheated and only took the panels partly off and wedged my hands behind to release the harness and pull the clips out.
Are the door panels tough to take off? Are these mirrors power close as well?
Sent from my SM-G900W8 using Tapatalk
Finally got some time to wash, clay bar, seal and wax before winter.
Also new tires...K02 275/70/18
Yes...that's a door ding in the driver's door.
Sent from my SM-G920W8 using Tapatalk
Well they can be a little difficult. There is the little cover piece down in the grab handle part that hides a bolt. I had trouble getting that out since I didn't have a correct tool for it. That hockey stick shaped shiny panel section in the center right below the grab handle snaps off with little metal clips. For some reason all my clips separated from the plastic panel piece and were difficult to get back on. One clip partially broke so the panel on one end does not hold as tight as before. I honestly stopped at that point. I did not want to risk breaking something just to remove the entire door panel. So I ended up just poping the top corner nearest the mirror out and then pulling back the trim around the window to give myself barely enough access to get my hand down inside the door to unclip the harness.
I just bought the basic tow mirrors so power adjust and heat, no power extend, fold, or blinkers. Same as what I originally had with the stock mirrors.
Added onto my tow mirror upgrade with a backup camera kit that is in the rearview mirror. Which I actually prefer, feels more natural while backing up since I'm already using my mirrors and I don't have to look down at the radio area. I've gotta say I really like these two upgrades I did. Money well spend in my book.
The camera install which beforehand seemed a little intimidating to me ended up going very smoothly. It took me a few hours as I really took my time taking the interior apart and getting it all hooked up. Very happy with how this project turned out.
  • Like 4
How did you do this?
Well, not sure if i posted it here or not but here it goes.
Got my Diablosport Trinity in last Tuesday. Updated it and threw it in the truck. First tuen went in great, truck ran like a scalded cat. Then i went to go mess with the mpg tune. Well, long story short, the tuner didn't reinstall the VIN to my PCM so i had to pop the PCM out and send it in along with the tuner.
Fast forward to today when i got it back. Popped the PCM in and started it. Runs good. Here comes my personal mistake, i tried to reinstall another tune into my truck. Bad idea. Now im right back to where i started. Will be overnighting it to them again tomorrow evening cause they are crap.
Clearly Diablosport can't figure shit out. Two times in one week. Whatever, ill just get my $500 back and go back to stock. The "tech" was getting upset with me cause i already went through the process that i went through with the last tech. Im a little pissed off considering my truck is just chilling in my driveway and its worthless right now
I bought the backup camera kit from www.cubbycam.com which seems like very good quality. It came with the tailgate handle with camera, which was prety simple to remove the access panel on the inside of the tailgate and swap out. It had a harness that ran from the back up to the underside the drivers side area which again was pretty straight forward I just followed the existing harness that ran along the outside of the drivers side frame using zip ties every 12 inches to hold it to the other harness. I had to pull up the carpet and drill a 1" hole in the floor on the drivers side for the harness to come up thru. This made me nervous but it had a rubber grommet and some sealant paste stuff to seal it up good. The replacement onstar mirror that has the camera image imbedded I swapped out and by removing the center overhead console which come out really easy, basically just pulls down and a couple screws. I then fished the new mirror harness above the headliner over to the drivers side pillar. I had to remove the visor, 3 screws, and the plastic pillar piece which come off easy too. Finished fishing that harness down the pillar and then down under the dash. The camera harness and the mirror harness connect under the drivers side dash. The last part, which again made me a little nervous was I had to splice (I used the t-tap connectors) into two existing wires of the truck that went into the BCM. In all it took me a few hours going slow and being careful.
We have a shop here in WA that also does this mod....
Sent from my SG Note 4 on Tapatalk
Wow that sucks. I'm a little surprised. I've used the diablosport intune on my previous 2005 and now my 2014 and have had nothing but great luck. I really like it. I've swapped tunes back and forth, going from both stock to tune and tune to tune never any issues. So it crapped out going from stock trying to put on a tune? What did they say they think is causing this? Where is the PCM located to take out?
First time was from stock to canned tune, said it failed, so i reinstalled factory tune and went to go start truck and it wouldn't start. This time, it was directly from stock to a tune and it failed, same thing i guess you could say haha.
No, they didnt tell me whats wrong. Told me its "unusual" for a GM truck to do that. Sounds like it happens a lot across multiple platforms. Don't go onto their forum, saw about 3 threads same truck related to mine. Not gonna attempt it again. Just get my money back and use it toward something else.
The PCM is under the hood, driver side next to the spare battery tray. Took me 2 min to pop out. 3 harnesses hooked into it, only being held on with plastic retaining hooks, kinda surprised there weren't any bolts holding it down
That's a little scary. I'm just going to avoid reading those forums, lol. Do you know if its the trinity's with the more issues or the intunes also? I guess the bright side is they can bring your pcm back to life. Sucks you gotta go thru this though. I've settle on a tune setup so once my free oil changes are up I'll probably just leave it installed long term and not touch it for oh the next 7-8 years.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 0 Anonymous, 651 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
