Out with old in with the new
49E2E6CA-DC1D-4F77-ABFF-A8FA48FEA866_zps
Literally didn't even get home from the dealership and picked these boys up already 22" cooper zeon ltz... New look on this one
6ABC8290-85CA-4317-ABFF-FF81C1127E17_zps
How did you mount the dual pods in the fog lights? It looks awesome!
Edited by crafferty
check out www.agricover.com/ledlights . I used there 18 W flood light , mounted on the hitch cross bar under the truck . size about 1.5 X 6 " . wire to my cargo lights
Do you have any pics of your installation you can share?
Finally finished installing the charging cradle for my Sony Z3 Compact phone. This phone has a magnetic charging connector on its side, and Brodit's cradle neatly uses this to charge while on the go. I attached it to Panavise's bracket that's made for the K2, which attaches to one of the OEM bolts in the IP.
Keeps my phone charged without a dedicated charging cable, and keeps it secure -- no more stashing it awkwardly in a cupholder. Ran the cables behind the I05 screen, behind the glovebox, and to the passenger side fuse block, where I used an MTR fuse tap from eBay to feed power. Works great, since I can just simply slide the phone in and out as needed, but I plan on also adding some NFC tags to the holder or dash to allow me to quickly turn BT on/off or load certain apps (i.e. Waze) when jumping in and out of the truck.
Also started installing a second pair of OEM LED bed lights. Have the passenger side one mounted and cables run; will probably slowly get to the driver's side lamp and tap into wiring as time allows this week.
When I got my truck someone had already tinted the taillights and I can hardly see to back up at night. The lights look good but they are painted. I wonder if these would help my situation? I searched Amazon and there are different versions of Cree 50 watt backup lights. What did you wind up getting?
Thanks,
Eddie
Eddie, see my third post on page 334 of this thread. I added a photo and link of what I bought.
Put some new shoes on her. Toyo Open Country AT II 285/70/17. Now to get my leveling kit on this weekend.
3d emblem inlays... They are not just flat vinyl overlays they are thick domef emblems that are raised and look really good. It's just the little details...
Edited by baggedlvintegra
do you have to wear 3d glasses for the 3d emblems to work ? :D
Well worth 25hp+
Added 10hp with my new decal
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Never understood this decal....Folks...you did not build this ..unless you work all positions at the GM assembly line.
  • Like 5
When you start adding lift kits and modding it yourself you're still building it from a stock truck. Now if you go out and buy the truck lifted, tuned, etc. then you bought it that way. Hence, "Built Not Bought"
You don't get it cus you don't see the full picture. That's what a 2wt trim looks like and that's how my 2wt trim truck looks like. I use this decal because all the parts on this truck I installed them myself, even made custom parts for stuff to work. That's what the sticker refers to, obviously not meant like I built the truck like I build cabinets.
DROPKICK Edition
Edited by NitroDatsik
  • Like 3
DROPKICK Edition
Ehh that sticker just makes me think of every stanced civic ive ever seen. Clean truck though.
Washed the whole exterior yesterday including underneath and this morning I decided to polish th driveshaft. Saw a it done on a SEMA build and thought why not haha. Was easy to do
F8F874B8-BF4E-4561-9486-DABF9E86C002_zps
Here's a before and after
BB8CEDC6-3C92-49B4-9CBB-EED856CE7C5E_zps
How'd you do it?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
