Washed it and waxed it. Needs to be clayed I think I will do that in a month or so before winter hits and put a nice sealant on it.
Sent from my HTC M9
How often do you clay bar your truck..
Sent from my SG Note 4 on Tapatalk
I bought it in June and I have only clayed it once. I will use a medium clay on it and iron x next month when I get it ready for winter.
Sent from my HTC M9
Put the boat in the water today for one last time before the winter come.
The KO2 TA is pretty quiet .
  • Like 4
Block8head where did u order the chrome tailgate everywhere I see it comes with chrome surround and the handle but I just want the chrome handle
That's the GM chrome tailgate handle.
Yes it's GM chrome handlle. Take about 20 minutes to switch it out.
Those with the pop lock on their tailgate key of the 2015 GMC sierra/Silverados.....
Does it use the factory key hole? Or does it replace the keyhole with another key?
I would prefer to keep the keyhole as the master key that matches the rest of the truck. I know earlier models had to replace the keyhole...
Edited by JacobC1983
Added the Zone 1.5 BL over the weekend. Directions were terrible but FastHeadlights video on youtube saved me! Thank you!
You replace a cam on the original lock with one provided by Pop-N-Lock. You continue to use the original key to manually lock and unlock the tailgate. I don't think you'll ever use it once the Pop-N-Lock is installed.
I added some underlights connected to my interior lights.
Sent from my SM-G900W8 using Tapatalk
  • Like 3
Installed the 50w CREE LED Reverse bulbs. Wow they are much brighter than stock.
Edited by brians09
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
