My 7 yr old sits in the back and she's always asking me "Is the heat/Air on"... Repeatedly.... Omg, GM really didn't do well not putting vents in the back..
Sent from my SG Note 4 on Tapatalk
2015's have vents under the front seats.
Wow, are you serious? Now I gotta go look.. Lol.
If you set your air to head and feet, then you will get a split and the backseat will get air from under the front seats.
Just looked, there is a low profile vent... And I do mean low. Need to try and tack down carpet under driver seat. It's raised to a point where 75% of heat is being blown under carpet.. Lol
Thanks, I appreciate it..
Bought her in April. Swapped chrome handles and mirror caps for color matched. Traded my chrome steps for blacks ones and bought the bed rails off the same guy.
Just wrapped up my exhaust. Truck is a 2015 RCSB 5.3
Kooks 1 7/8"
Kooks 3 to 3 1/2" catless y-pipe for a 6.2
MBRP 3 1/2" 6.2 cat back modified to fit a RCSB
Here is a vid of a cold start.
I will get a vid of a warm start and warm idle. Once the engine warms up the timing changes and makes a very noticeable difference. Gets much quieter and deeper.
The mic on my phone cannot pic up the full definition of the exhaust note.
http://vid81.photobu...663EF8316D5.mp4
A/C went out, trip to the dealer. They were all over the problem. Leak in a pressure hose, replaced the part, back on the road in about an hour. 34,000 miles. Saw a new 2500 ltz duramax ltz dressed in black, color matched grill, bumpers, headlight trim.. Has me thinking.
That was mostly likely one with the "Custom Sport" Package. Pretty reasonable actually. Black painted bumpers, painted grill surround and headlight surrounds, 20" wheel upgrade, different badging and some misc things. $1300.
Once you figure the cost of doing the 18" to 20" wheel upgrade as a separate option, that is a great package.
Isn't that the sport edition or something like that? Seen one here in WA.
bebc527c2f685cef9ad29cb9bd09eeb1.jpgis this it... Not sure if this will work...
Finally got rid of my deer bent bumper and got an iron cross that came in today.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
