Not quite today, a few days ago to compare my new beam pattern
2015-10-11%2000.02.43.jpg?dl=0
Low beam2015-10-11%2000.02.55.jpg?dl=0
Low beam with fog2015-10-11%2000.02.50.jpg?dl=0
Highbeam with fog2015-10-11%2000.03.38.jpg?dl=0
Low beam2015-10-11%2000.03.54.jpg?dl=0
Highbeam with fog
Thanks bro, yes the wheels are -44 offset. I trimmed quite a bit, the rear of the felt liner was cut and metal was also cut. 20x10 would fit with almost 0 issues on just a level, plenty of guys run that. 20x12's are a little tougher though, I've seen some guys run true 33's like the RT's & MT's on x12's and leveling kits but they must've trimmed pretty heavy. A 1.5" body lift would help you out a lot. I know two guys that run 22x12 on 33x12.50r22 with a 3.5" RCX lift. So you would be at 4" and should be able to run that, but you'd still have to trim.
Thanks for the info. I think just to play it safe for now I am going to run some 20x10's -25 offset until I get ready to lift and then switch it up to 22x14's -76 offset and some 37's or 35's.
How high are you going? In order to roll 37's and -76mm offset x14's you're gonna need about 10in. of lift on a 1500
I haven't seen it in person but I have seen pictures and heard of guys running the Mcgaughys lift set at 9 inches and run that setup. They have a photo of a truck on their website for that lift and that's what it's showing. Hopefully it will work.
appreciate it! Ground to wire or body?
I just grounded to the body. There is a few bolts under the dash that are easily accessible.
I hope somebody does a write up on the footwell lights.
What would you like to know?
Feel your pain man, I was in that same exact boat. Want to keep it all P rated (or XL which is still P) and go bigger. Very hard lol. If your happy with your height, go 305/50. If you want a little more consider the nitto's. Lemme know what you decide man, either way it'll look miles better than 275.
I found the 305-55-20XL Nitto G2's for $265ea. Normal like $320-$340. Think that is gonna seal the deal for me!
Installed Airraid MIT. Satisfied with the look of the cleaner bay. The plastic clips that came with it to secure the tubes are a little weak. I'll be replacing them with the metal screw clamps eventually.
Put on the "winter" wheels/tires today... GM accessory wheels 22" CK164. Bridgestone Dueler RH-S 285/45/22.
Poor Luster. Looks like you are having it a little rough at the moment. #JEALOUS haha
O! beware, my lord, of jealousy; It is the green-eyed monster which doth mock the meat it feeds on
William Shakespeare
Installed an Access Vanish roll-up tonneau cover.
That looks like a nice tonneau. I just went with a tonnopro lo roll and I do love it, but yours looks a little cleaner at the tailgate. I have to pop my tonnopro and roll it back one roll then close the tailgate to get the seal to sit properly with mine. Not a big deal, but I would have preferred a system that allowed me to just open and close my tailgate without having to pop the cover every time. I don't open it all that often so not a huge deal, but convenience is key.
How do you like it? Does it seem like it will seal out water well?
How do you like the Airraid MIT unit ???
    1981dustin
    1981dustin
  • Who's Online   1 Member, 0 Anonymous, 1,564 Guests (See full list)
