http://www.amazon.com/gp/product/B000XBCURW?keywords=303%20aerospace%20protectant&qid=1444259086&ref_=sr_1_2&sr=8-2
It is a good product. It is UV resistant.
I will let you read the reviews but I have been using it for a few years and I am happy with it.
Thanks a lot brother. You're a truck enthusiasts just like me, so I'm taking your word.... Appreciate you.
Sent from my SG Note 4 on Tapatalk
I'll have to look at the front skid plate closer. But from what I can see the tow hook is fine.
Ok well if the skid plate and tow hook valence aren't damaged I'll buy those from you
iPhone 6 '14 Silverado
Ok. Bumper should be in roughly 3 weeks from now. I'll check in between then and wil DM you if everything looks good
I use aerospace 303 as well. You can get it on anazon. Works excellent to keep black plastics looking new. Great for vinyl tonno covers as well. I learned about it from a jeep forum - kept my soft top looking brand new.
Got to haul our empty 16' utility trailer around to drop off some material at a job site.
Every time someone says to use e85 when towing just show them this post.
Hand calculated 11.07 mpg on e85. Towing an empty utility trailer for 264 miles, only actually towed any weight for less than four miles. With a loaded trailer I would be hard pressed to believe I would even touch double digits. While there was undoubtedly more power available the poor range just makes it impossible to continuously run e85.
On 93/91 I would of gotten ~17.5mpg on the highway with an empty trailer easy.
Finally had some time to work on my front end project.
Please tell me the switch to turn on that light bar is this one? Lolea317e08aa6ca7359268b27cfe8dc390.jpg
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
  • Like 4
U should definitely try this with 93/91
I get like 14mpg with my empty utility trailer (16'). Average 11mpg loaded down. I also drive it like I stole it so I'm sure that doesn't help
Even light output with sharp cutoff using stock projectors and adjustable offset LEDs!!
DROPKICK Edition
You mean this button? lol Surprising enough because of all the holes in the octopus it doesn't block very much light bar light.
  • Like 6
Anyone know what colour wire the dome lights might be? I'm hoping to tap into it so I can add some lighting for when I open the doors. This is the best I could find, and I'm still a little confused.
http://www.silveradosierra.com/electrical-manuals/2014-silverado-wiring-info-t228266.html
NitroDatsik? You're kinda the lighting guy, maybe you can help me out. Thanks.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
