Great mail day for the truck :)
0517C917-C692-4639-8008-F895A2807485_zps
Is that a Honeycomb grill and "A" pillar asst handle?
Sent from my SG Note 4 on Tapatalk
Got the windows tinted the other day....and today, well....I wiped off about 10 bird bombs. Yuck.
Edit: just ordered my rear mats ( husky xact) finally....also ordered a pet hammock and the kurgo pet door guards, all with my CC rewards....can't beat free. [emoji12] [emoji106]
Sent from my Note 4
Edited by werked
Installed a set of 35w HIDS, now to make the fogs match color..
Sent from my SM-G920W8 using Tapatalk
Yeah, Ram Mount. Unfortunately in our lovely state of NY I don't think carrying around an "evil featured" rifle would be ok (great looking build on that AR though!)
OK. I'll post when I get a chance, buddy. Yea, that's why I can't stand NY. Visiting is cool, but can't pay me enough to live there b/c of their "gun-friendly" laws.
Edited by dt4629
Added the basic tow mirrors this morning. I have to say it is a bigger pain in the rear to install these than it seems like it should be. Why stuff the wiring harness halfway down the door behind the door trim panels. Makes a quick easy task into much more work. But all went well in the end. I cheated and only took the panels partly off and wedged my hands behind to release the harness and pull the clips out.
Pics don't do it justice, but got the grill installed, 2.5" leveling kit, 22x12 305/40 Cooper Zeon LTZ, AMP steps... Drop the bumpers off Monday for powdercoat and the fender trim off for colormatch and cleared Line-X
22F94004-F0B5-4534-A5E5-351068511A93_zps
  • Like 7
Retrax installed
efbdb0c196bf4ce47edbe4bb0bb87fd5_zpsaano
Line x platinum
457f8ab9dc76dc65943275570b21754e_zpsq7l6
Nice bath
ae93c4a066bf3904ea7c7358e23bff8c_zps2zmd
Edited by Sal9012
  • Like 7
Installed WeatherTech No-Drill splash guards and an Access Vanish Tonneau today. Also included a few pics of the Bullet Liner I had installed a few weeks ago.
The output is ok since it's halogen. The projector is Bi- Hi and Lo built-in.
The adjust screws is easy to access to.
You have any pictures of output of these projectors? Are they better than your Stock ones?
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
