Nothing major, just riveted a piece of flat bar in the toolbox so the magnetic work light could stick somewhere. Had the flat bar already, so it only cost me $15 for the light (thank you Amazon prime) lol
Also added a tool set from Harbor Freight, $160 with the 20% off coupon. Has almost everything you need besides a decent set of wrenches
Edited by rdnckhntr94
You almost have as much stuff in your toolbox as I do. Sometimes if something isn't in place right I can't shut the lid so I have to adjust a couple things lol. I sure as hell wouldn't be able to even have a low pro which I don't care for anyways. The underseat storage box under my back seat and the lockable storage place under the front middle seat are also filled up completely. I didn't realize I had so much shit until I bought the '14 and had to swap everything over lol.
Edited by SouthernSilveradoGuy85
I try and keep my inside clean incase it turns into a people hauler all of a sudden lol. But my work tool bag used to fit in the box but since I added that tool kit it won't anymore, just have to live with it I guess. If winter ever decides to give up around here I can clear out my backseat of the 6 jackets I got back there lol
Installed a 6inch sub in my center console.
Finally installed some different wheels. XD Series 20x12. e650c3c456648a3892d3e265e7b965c0.jpg689269a13065af0317d2f92a7c65ac64.jpg
  • Like 5
Installed my Morimoto hid kit. The harness was kind of a pain to route, but its perfect now. I had 6000k in my last truck and these are 5500k. It'll take some getting used to.
Put some vinyl wrap on the grille surround. Really like the way it turned out though it was a lot more challenging than expected. Probably should have just paid someone to do it
Before
After
Installed new media module today from gm-navigation.com
Adds video in motion, navigation in motion, and text messaging capability.
What module did you buy because I looked on their website and I couldn't find the one that enables the text messaging. I found the one that bypasses the navigation and video watching but it didn't say that it enabled the texting option.
The color I guess is what will take getting used to? I just ordered a 5500k kit myself, couple parts on back order though so they should be here in a week or so.
Edited by jrob56
can you post web site / part number / cost ????? I like to add this also. maybe more photo's when installed. Thanks
Going on this weekend...
1DF7196E-F100-4DA4-A64B-3BB906FB6520_zps
looks good - just tips / or whole system
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,320 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
