can you post web site / part number / cost ????? I like to add this also. maybe more photo's when installed. Thanks
http://gm-navigation.com/2013-2015-gm-video-in-motion-and-navigation-unlock.html
I found the right module but it doesn't list the price, it just asks you to contact them.
I also found them on Amazon for $250
http://www.amazon.com/Video-Motion-Navigation-Unlock-HMI/dp/B018F3I7B2/ref=sr_1_1?ie=UTF8&qid=1458846669&sr=8-1&keywords=GM+Video+In+Motion+And+Navigation+Unlock+For+HMI
Finally :)
is that a rhino RB-10 running board ???? How do you like it ???? GOOD Looking truck
Edited by tahoe08
Yes. They're great so far. I really didn't want to put any running boards on my truck, but the wife won that discussion haha.
Josh
Josh
I'm sure it was less of a discussion and more of her telling you to get steps lol.
Oh yeah. From the day I lifted it that's pretty much all I heard :)
Josh
Installed Duraliner bed liner and had shop install exhaust, Spintech 6000 Series 3" in 2.5" dual out with MBRP 2.5 to 3.5 tips.
Had the front two windows tinted as they were not done at the dealership and they wanted way too much to do it.
Looks a lot better!
Had mine done today as well....very happy. And I agree, looks a LOT better! Best $75 spent on the truck yet. lol
Edited by Brian2015
I finally installed my Hellwig Rear sway bar. These trucks handle great to start with but the rear bar really makes a big difference. I highly recommend it. Installing the AR Headers tomorrow
RT
Edited by 07Softail
The color I guess is what will take getting used to? I just ordered a 5500k kit myself, couple parts on back order though so they should be here in a week or so.
Yup, just the color. It's not as blue as the 6k, but I really like it.
Installed some footwell leds just like in the first post on here and got my auto dimming mirror in the mail today. It'll be going on later today or tomorrow. This thread has some great inspiration.
Finish lift kit and clean her up.
Sent from my SAMSUNG-SM-N920A using Tapatalk
looks good
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
