Tell that to the $100 ticket I got for having my offroad lights uncovered...not in use, just uncovered.
And a friend got tagged for not having his fogs on with low beams. That was $87.50...
And still another friend got his inspection rejected for not having lights on with the highs and for having tires past the fender well (by a 1/4" mind you).
Don't tell me, or preach to everyone on here, that it won't happen...
Sent from my SM-T350 using Tapatalk
You gotta move...
Can be very location specific. Here in Florida the whole state is pretty good except for Tallahassee. It is the capital and they have an over abundance of traffic cops apparently under orders to ticket anything they can. Window tint tickets, crooked licence plate tickets, but don't worry, you can still buy all the crack you want.
Did the paint to match swap a few weeks ago and dual fog light mod. I still need to adjust the fog lights a little. Also added midnight edition headlights and just installed my 305/55/20 falken wild peak at/3 tires. 6dba189da7439f699d4d130305218c7c.jpg6afe4062ab9e0694a94c7de32d260339.jpgcd5a9e691545adb866b4d4cfd27c0a68.jpg6fe518b5d476b2d073fb625748a720a1.jpg
What fog light pods/mount did you use? I like the look of them; I have something similar but they are the smaller Rigid lights/mount. I didn't think the ones you have would fit in the housing.
Just a set off eBay. No name brand. Just a 3in cube. Didn't use a rigid mount or anything. Just drilled a hole in the plastic bucket and ran the bolt thru to mount.
Nice; thanks. They look great!
I guess I was lucky this last winter when I visited a buddy in Erie, PA. Driving on those back hilly snow coverd roads with huge ditches required all the light I could throw at it, until the lake effect snow came in. In the metro Detroit area people drive with their lights on, last night a ford with pods by the a pillar, led factory fog location, and some steer horns on the hood ... it wasnt blinding because he had everything pointed down.
How much for the headlights? I want to upgrade to a projector headlight but OEM is pretty expensive.
G2axle differential cover arrived today. Weekend installation while changing leaking axle seal.8434562ebee43b190c2ba924fc52e0a7.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
  • Like 3
It was a set of eBay, don't waste your money. Save up and get OEM I made that mistake. These things are not that great. I have them adjusted as high as they go and can barely see on the road the beam does not go high enough. Luckily I run my fogs on back roads for the time being till I hit The city, turn them off and it's OK but I'm back roads or anything like that they are junk. Wish I didn't buy them and waste the money on painting the trim. I am now saving up for OEM midnight edition headlights or if I can come across a set for sale I will snag them ASAP
Edited by MHPrior80
did the foglamp mod.... then took it out.... reason being.. when i auto started the truck.. they turned on... ..i cant turn them off now.. which i normally dont drive during the day with the day... .. but it was super easy and took like 2 seconds.
also did the reverse light mod.. i noticed.. that when in reverse they didnt come on.. but when i turned on the bed lights when truck was off.. the reverse lights came on.... .. i thought the bedlights would come on .. when i was in reverse... no biggie.
For the reverse lights, I used a piece of wire, not a diode so they come on in reverse, or when I turn the cargo light on.
yeah maybe the diode was stopping it from doing it the other way.. .i'll try the wire !
thanks man!
Make sure you got the correct pin, sounds like you hit the the DRL instead of lowbeam.
Diode was reversed.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
