First of all, I'm definitely not an expert on this subject but what I got out of it by talking directly to Tracy at RevExtreme, due to the nature of Direct Injection oil ingestion through the intake causes a build up of oil on the valves. Overtime it builds up and causes problems with the valves. The catch can and clean side separator redirects about 90% of the ingested oil to the catch can where it can be drained periodically instead of having to deal with valve build up. Without this setup only about 30% of the ingested oil is removed where it is burned through the exhaust system. It sounded plausible to me and, as I understand it, they are installed at the factory on the "go fast" Camaros which made me decide to get one. Does it work?...I don't know but I figured it couldn't hurt.
If you want the real skinny on these catch cans/clean side separators call him (Tracy) at 941-721-1826, and ask him directly. He can explain the whole concept much better than I can. But, like I said, it made sense to me.
I hope this helps.
Edited by LTZTom
Had my Corsa Sport CatBack exhaust installed today...what a roar.
You know the rules of the interwebs... clip or it never happened....
Nice looking Truck!!! Tell me about your grille. I'm thinking that would look nice on my Emerald Green Truck.
Edited by scooot3
Line-X spray in bed liner... love it!
That looks like a Brownstone Colored truck. I know line-x does a semi Colormatch. Did you see if they have a brown color?
Go Army! GO ORDNANCE!!!
Actually the truck is Tungsten Metallic and the bedliner is plain black. It's just the lighting in my garage.
Plasti Dipped my wheels.. Temp fix till I eventually get black wheels.
Also thinking about dipping the front grill and headlight trim, so the only chrome would be the front and rear bumper and lug nuts.
Its the little things.
My LT came with black plastic. Picked these up on eBay for 35 bucks.
Sent from my SM-N900T using Tapatalk
That actually looks really good. Hmmm time to plastidip
tyqady8y.jpgHere it is, took a long time to upload but is done
Watch "2014 Silverado Anzo Headlights" on YouTube
2014 Silverado Anzo Headlights:
those lights are awesome! I'm trying to hold out and wait for the price to drop.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
