Just finished up the install of my mazulla off road skid plate and bumper tube. Got rid of the ugly lower valance and gained some ground clearance up front. Very happy with the finished result.
  • Like 6
What % you going with?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Front window strip 5%, driver and passenger 15% and backs to match front.
One dealer told me they wouldn’t do anything for my shot balljoints because of a leveling kit.
My new dealer replaced a tie rod that was clearly due to my lift and did some other warranty work. I have something of a friendly professional relationship with the service manager.
If you find the right service manager, are friendly, and don’t demand things and act entitled to warranty coverage, you can actually get a lot of things done with a nod and a wink.
Lol, will do I’m just going to wait for my oil change to come up, I also need them to fit my back doors. They stick out so far.
I figured if one place says no I’ll go to the gmc dealer down the street.
Update on the build.. cutting rest of wheel wells and adding all bumper leds tomorrow.
Still a LOT of work to go!
  • Like 3
Good looking truck. Is it a 1500 or 2500?
What lift did you go with? Also, are those 37s?
SuperLift 8” with king suspension and 35s on 22x14 for now as I didn’t have my custom bumpers until today so couldn’t run 38s then.
But with 14 wide.. it also doesn’t look like I can run 37s or 38s now.. I do like the wide tires as I plan to do shows.
Came out good. I was thinking about 22x12, but 22x14 look more aggressive.
Today bought a new lift, went with 7-9 McGaughys along with the Add a leaf, cognito control arms, and some 4.88 gears! Can’t wait for everything to get here!
  • Like 3
Why the 4.88, Yukon recommended 4.10 for mine.. unless your going to roll on 38’s maybe?!
Stoked to see yours next!
Talked with one of the guys from Randy’s ring and pinion and they advised either 4.56 or 4.88 due to my lift be a total of 12 inches and my tires are 37s with the 24 inch rims making each tire/wheel combo be about 100lbs each. They said the 4.56 will be close to stock and the 4.88s would be for a better experience and have that get up and go
Do you have a build thread? Truck looks good and would love to see more pics
Looks good - what size wheels/tires?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
