Soaked Rear Carpeting
diannabill
Again how would the rear mats be dry on the surface, but soaking wet underneath if the sunroof was leaking? There would be evidence of water on top of the weathertech floor liner since its basically a once piece tray...gravity, while amazing isn't magic.
Go back and read the 2nd paragraph in the OPs 1st post and you will see there are 2 different issues he has. Not just the water under the mat. :nonod:
Go back and read post 3. A sunroof could attribute to the noise of water but not the water leak itself as won said gravity would bring the water in? Two separate conversations going on.
If the water is comng in between the apholstery panels and the cab, I don't think you would ever see it on the floor mats. No one would notice it until, like you, they found the wet carpet. I doubt the dealer would ever check that but I know I'll check my '13 next time it rains.
Mike
Thanks. No need for me to go back and read anything I'm following along this thread just fine. Just got to take what Won says with a good laugh sometimes.
Just got mine back from the dealer today. One of the things it was in for was a water leak. I had water dripping from the drivers side sun visor mount. They tell me it turned out to be the seal for the sat antenna. They also applied the recall fix and an update for the climate control
Mine truck had the same issue water was coming in around a bad seal on the cab of truck between the bed and cab. The seal kinda looks like flaps on your dryer vent on the outside of your house. It's there for cab pressure so the doors don't bounce back when you close them. Dealer fixed it same time they did the back window recall. Water runs the inside behind the back seat and pools up underneath the mat under the carpet
It seems to me they're going to find something that can only happen when the truck is in motion in wet conditions. Since it sat somewhere for 3 months before it was sold to me, if it was just rain that did it, it would have happened before. Even here in my driveway the rain didn't seem to wet the carpeting. But after a few times of driving in rainy conditions is when it happened.
It only showed up after I put the weathertecs in. I'm blaming them! LOL
Hey mdes0 and philbun,
I'm happy to hear the dealer was able to address these concerns for you and get you back into your trucks and on the road!
diannabill,
If you would like us to follow up with your dealer for you feel free to send us a PM with your name, contact info, VIN, current mileage, and involved dealership.
Sincerely,
Jonathan A.
GM Customer Care
I opened one of the back doors after a rain and enough water came out to fill one of those small chinese soup containers. It just kept pouring out. Waiting for the bottom of the door to rust off
Coming out of the bottom of the doors? Isn't there some kind of drain holes on the outside of the gasket?
You would think. This was coming out of a hole towards the front of the door on the underside. don't use the back doors a lot, guess I will have to open them after a rain,or put in some gold fish.
PS I was telling my wife about the large amount of water coming out and she said the same thing happened on the front door same side the day before when she went out to get something from the truck. Man I love this truck
Got my truck back today from getting the leak situation fixed. It was a small (very small) hole in the vertical seam just below the right side of the rear window. I guess the combination of parking on a slight incline and all of the water channeled from above the rear window was enough. Hard to believe that small of a hole would be that big of a source of water, but that's their story and they're sticking to it!
They resealed that area and the carpeting dried out quickly. I asked if there was any concern for mold and would they consider new carpeting, but my dealer said GM does not replace carpeting simply for a leak.
Anyway, we'll see how it goes!
hopefully they pulled out seats and then the carpet, dry it out thoroughly, and disinfect it. You can dry out carpet on the surface but the insulation and sound deadening material attached to the underside will stay wet for a very long time. After about 3 days, you'll start to smell an overwhelming stench. Hopefully they did right by you.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
