Why they chose to put that chrome window trim on these mostly otherwise beautiful pickups is absurd.
Sent from my SM-N910V using Tapatalk
Anyone want to trade their black trim for my chrome? I have a '16 Sierra Crew Cab
Where are you located? Not so much for shipping, but can't really drive around with those missing...
I'm in Michigan, Detroit area
If nobody wants to trade you but you are interested in buying I have a brand new set of black ones listed in the For Sale section. You can buy mine, put them on your truck, then sell your chrome ones to Hisdem :)
Edited by sk
Sweet. Link to ad?
I have a set of chrome window trim for a crew cab I am looking to trade for black. I would also like to trade my chrome handles and mirror caps for deep ruby. I'm in the Austin, TX area if anyone is interested.
Also looking to trade up some chrome trim off my double cab sierra. let me know if you're looking for any.
I have factory black window trim and handles. Willing to trade for chrome of the same. 2014 silverado crew cab.
I have a set of Double Cab Black trim in perfect shape for sale. 2014-2016. All the clips are great. $120 shipped to your door.
Any one in canada wanna swap, I have a crew cab with all chrome trim wanting black
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 270 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
