My truck stalled while fueling today!!!
losky79
As already mentioned by others, that is a classic EVAP issue by the "topping off". Had a know it all jack hat at work that learned a hard lesson about topping off his Volvo and trashed his charcoal canister. After diagnostic and replacement, he was down $1800 in the hole and the warranty does not cover operator error.
I agree with the diagnosis of fuel in the evap lines, but y'all are over reacting to the engine running while fuelling. In the middle east (my dad retired from Chevron and we lived there when I was a kid, and I travelled their frequently for my current job) almost everybody leaves their cars running when fuelling up because it's so freaking hot. I've never heard of a fire incident. It's probably frowned upon or illegal in most states, but it's not that dangerous. Even with your engine off, the exhaust and engine are still plenty hot, so that's not reason for concern. I still don't see what the big deal is.
totally agree and in northern plains it's very common to do the same when it's cold.
Another situation that I never shut down to fuel is when I'm on a road trip and need to fuel, I always give it a few minutes of idle after coming off the highway.
Hey losky79.
I’m sorry to hear that you experienced this problem with your vehicle. I do understand your concern and I’m glad you and your daughter stayed safe. I would like to take a better look into this. If I can be of any assistance, please private message me your VIN so I can reach out to an internal resource. I look forward to assisting you.
Kristen A.
GM Customer Care
Hello losky79,
I'm sorry to hear of the concerns you are having with your vehicle. I can definitely understand how feeling uncomfortable in your vehicle can be frustrating. I would be happy to look further into this for you. If you'd like my assistance please send me a private message with your name, phone number, address, VIN, current mileage and involved dealer. I look forward to assisting you!
Thank you,
Andraya R.
GM Customer Care
Gm bots? Sent from my XT1055 using Tapatalk
They are customer service reps from GM who can assist members who are having trouble. It is to your benefit that they visit.
You are willing to endanger your kid's life so the heater would be nice & warm when you got back in the truck?
How was his kid's life in danger?
On any modern vehicle with the closed system , vapor recovery, computer controls etc. your asking for trouble fueling up with it running or topping off. My wife is terrible about topping off. Every time she fuels up the Blazer she keeps cramming as much it as she can in it. Can't get her to understand its not good for it. As least she shuts it off.
i remember when some stations had static straps - to me static discharge is much more a risk thank leaving an engine running to cause a fire - the exhaust is on the other side. I shut down but that is from habit. I believe static electricity or SMOKING (yes I have saw that too) is much more dangerous
I'm always careful with my lawn & garden fuel containers also. I take them out of bed and set them on the ground first.
Half the people here are overreacting. Yes it not good to top off and yes it should be common practice to turn off the engine. But when was the last time someone's car blew up or caught fire while filling cause it was running. I'm sure more then half the people operate a cell phone while fueling. I don't see them bring that up...
Flash point of gasoline is around 530° and ethanol is around 680° So you would have a better chance of static electricity (spark) to ignite fuel.
Tapatalk via Moto X
You probably got fuel into the evap lines and that sent raw fuel through the vapor lines causing a flooding of the engine. Sent from my iPhone using Tapatalk
The above reply is the answer to your problem of what happened.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
