DOD - GM Chris Meagher Asst Chief Engineer
http://www.superchevy.com/technical/engines_drivetrain/accessories_electronics/0405sc_gmdod/
In describing GM's new fourth-generation small-block, we run the risk of sounding like that popular light beer commercial, "tastes great, less filling!" As silly as it sounds, the technology packed into GM's new Gen IV powerplant does allow one to have his proverbial cake and eat it too. Fuel efficiency and power are two goals high in any engineer's criteria; they also happen to be important to GM's customers. The down side is that they are usually at cross-purposes where one goal (fuel efficiency for instance) must be sacrificed for the other (power). Unfortunately, it's a compromise we're all too painfully aware of in our questicon1.png for performance.
We recently got a chance to sit down with Chris Meagher, assistant chief engineer of small-block truck engines at GM. And while we were initially intent on milking every last bit of information concerning the Corvette's new 400-hp LS2, we quickly realized that the real technology party is happening in the more utilitarian 5.3L version know as the LH6. As it so happens, the LS2 is a subtle evolution of the LS1, so we'll let the other magazines focus on it and we'll concentrate on the much-anticipated displacement-on-demand technology, which has managed to pass the LS2 by.
In our brief one-hour interview, we learned a lot about what the future of hot rodding will look like. In some respects, it looks very similar to what we've seen with the Gen III LS1 and LS6 engines, but in other ways, it's an evolutionary leap forward. Chris Meagher explained the impetus behind the redesign: "The design goal is pretty simple, we wanted to take the 5.3L V8 and make it more efficient. We wanted the customer to have the same characteristics of throttle response, power, general performance and towing capability that we had with the original LM7--and provide the customer with a more fuel-efficient package."
What GM Powertrain came up with--the 5.3L LH6--is almost identical to the outgoing LM7 on the surface, but technologically advanced on the inside. That technology enables cylinder deactivation (called displacement-on-demand or "DOD" by GM insiders) during periods of low load demand and is the source of the increased efficiency mentioned earlier. "We know that there are a couple of areas that we can attack to make an internal combustion engine more efficient," says Meagher. "These areas are mechanicalicon1.png efficiency, pumping losses, and unused heat energy. We knew that we could attack the area of pumping losses relatively easily with our displacement-on-demand system. That's the area this system addresses."
While typical hot rodding tricks revolve around making the engine bigger or getting more air and fuel inside an engine, the engineer working for the factory can't always afford the luxury of this approach. The working principle from the engineer's point of view is that the power available is what's left over after you take away everything else that robs power, such as friction and pumping losses. Meagher explains: "Pumping losses represent the work needed to bring a fresh charge into the combustion chamber and to expel the products of combustion. We have some tools that can simulate the vehicle performance characteristics relative to fuel economy. When we looked at mid-sized utility vehiclesicon1.png, we saw that we could achieve about an 8 percent increase in vehicle fuel economy."
To an engineer, eight percent is a huge improvement. At the gas pump or on the dyno, it's also a huge improvement. "Displacement-on-demand is a win-win for drivers who rely on the power of the small-block V-8 and are conscious about fuel economy. The implications of this technology are tremendous," says Meagher. For now at least, those implications will be exclusive to three vehicles, the 2005 Chevy TrailBlazer EXT, the GMC Envoy XL and Envoy XUV. But before moving on to the nuts and bolts of DOD, we'd like to point out that it has far-reaching possibilities for performance enthusiasts. Had GM elected to apply DOD technology to performance vehicles such as the Corvette, GTO or a future Camaro, there would be far less pressure from corporate average fuel economy (CAFE) to import sub-compacts from outside GM as is the case now.
The bottom line is, DOD on more carsicon1.png could mean more--and better--choices for enthusiasts. As an example, an early prototype C6 Corvette with an LS2 running DOD provided equal power and acceleration to an LS2 without DOD, but produced 35 mpg instead of 30 mpg. When applied over a large volume of vehicles, GM could have the choice to pocket the improvement in economy and reduce the need to import small outside-sourced cars, or it could build a larger V-8 with more power (say a 6.5L V-8 with 430hp) and keep the same 30 mpg. In the end, for reasons not entirely understood by us but conceivably related to exhaust packaging, DOD technology did not make it into the C6 Corvette, GTO, CTSv or any other performance application as we had hoped. One thing Meagher did share with PHR is that the goal of DOD (on the limited range of SUVs currently planned) is to allow additional vehicleicon1.png mass (in the form of increased content) without a commensurate decrease in fuel economy or performance.
All corporate politics aside, the engineers at GM Powertrain have designed yet another mechanical marvel, and it's all due to some remarkably modest changes to the very robust Gen III architecture on which the Gen IV is based. The new DOD-specific hardware includes two-stage switching lifters, a lifter oil manifold assembly (located in the valley of the engine), a redesigned lube circuit and oil pump, electronic throttle-by-wire operation, a pressure-activated muffler valve, and an improved E40 engine controller running DOD-specific software.
"In order to eliminate the pumping losses," says Meagher, "you need to disable both the intake and exhaust valve." This results in a completely sealed, deactivated cylinder, which is essentially an air spring being acted upon by a piston. Virtually all the work put into it during compression is returned to the crank during decompression, finally giving credence to the old joke about piston-return springs. (That's nothing. Wait 'til you hear about the muffler valve...)
"Currently, we could disable just the fuel delivery," says Meagher, "but the valves would still be opening and closing and each cylinder would still be doing work pumping air in and out. So there would be no net gain in efficiency--you wouldn't have eliminated the pumping losses at all."
In support of cylinder deactivation is some very interesting choreography from things ranging from throttle valve modulation to active exhaust tuning, but it all starts with the additional job tasked to the lifters. "We disable the valves through a device called a switching lifter," explains Meagher. "This differs from a normal lifter in that there is an inner body and an outer body connected by a spring-loaded pin. For V-8 operation, the pin is fully expanded by the spring so the two pieces act as one and the lifter acts like a regular lifter. When we want to disable the valve operation, we deliver high-pressure oil to a groove in the lifter that leads to the outside end of the pin, forcing the pin to collapse the spring. Now the two parts of the lifter are free to move relative to one another and as the cam lobe pushes on the follower the inner portion of the lifter pushes against another spring at the top of the lifter and does not transfer force to the pushrod."
A look at the lifter cross-section reveals an elegant, yet simple design that has the potential to change the way we think about traditional pushrod engines. (Ironically, when DOD is working, it hinges on lifters that do not lift! Something we never thought we'd ever want.) In order for the switching lifter to work effectively, the engine needed a redesigned oiling system. Both iron and aluminum versions of the engine block have redesigned oil galleries to support DOD oiling requirements. Those oil galleries are supplied by a lifter oil manifold assembly (LOMA) located in the lifter valley of the engine. Under cylinder deactivation, the LOMA routes oil to the applicable lifters by means of four lifter oil solenoids, which are controlled by a new E40 engine management controller. To supply the additional needs of the cylinder deactivation circuit, a higher capacity oil pump is fitted to the LH6 engine.
For the most part, the Gen IV engine family is very similar to the Gen III (LS1, LS6, LM7, LQ4, LQ9, etc.). Although the two are externally similar, there are several significant differences, which impede the interchangeability of some parts between Gen III and Gen IV engines. For one thing, the real estate required by the LOMA and its attendant electronics forced the relocation of the knock sensors and the camshaft position sensor. Since DOD relies on the use of electronic throttle control, the throttle body is not interchangeable with earlier cable-actuated throttle bodies. In concert with these DOD-specific changes, an improved coil-on-plug ignition system (which requires less energy), a returnless fuel system, and uprated LS6 cylinder heads (minus the hollow sodium-filled valves) have been employed. Fortunately, the cylinder heads do retain interchangeability between Gen III and Gen IV, which could prove to be a boon to older LS1s.
Readers who remember the 1980s will recall this isn't GM's first rodeo with cylinder deactivation. That first happened at Cadillac with the 8-6-4 engine, which was roundly criticized for its service record and its poor vibration (NVH) characteristics. The old adage of once bitten, twice shy applies here not only to potential LH6 customers, but also to the folks at GM working to make Gen IV the best engine architecture yet. GM's Meagher quickly points out the lessons learned: "I worked on the V-8-6-4 earlier in my career and [the LH6 is] the same idea. The key difference is the control system configuration. The key part of it that makes the transition imperceptible is electronic throttle control. Once the computer determines operating conditions are met to enable DOD, it uses engine vacuum as an indicator of customer power demand. When the computer decides to disable four cylinders, it calculates where the throttle needs to go such that the torque will be equal when you end up with four cylinders."
With the different modes of cylinder deactivation in the Cadillac 8-6-4, there was a dramatic change in NVH, and a corresponding difference in throttle response and exhaust tone. All of these were deemed unacceptable in a luxury car, and at the end of the day, the improved vehicle economy wasn't capable of offsetting the loss of comfort and power. In one sense, the failure of the Cadillac was a windfall to DOD engineers because the design obstacles had been clearly defined years ago.
In the LH6, the transition from eight-cylinder operation to four-cylinder operation is aided by electronic throttle control (ETC). At no time does the driver perceive a decrease in engine power when in V-4 mode because ETC applies a seamless increase in manifold pressure. (Translation: when the engine switches to four cylinders, your foot is still pressed the same amount on the gas pedal because the computer has opened the throttle more without you knowing it.) An increase in power demand is just as smooth; there is no dramatic surge in power during transition to V-8 operation beyond what is expected, that's because the ETC closes the throttle in conjunction with cylinder activation.
Meagher told PHR: "One area of dissatisfaction [with the Cadillac] was the transition feel when going from four to six to eight, or from eight to six to four cylinders. The reason that electronic throttle control helps that is that we are able to move the throttle with the computer, not the pedal. The computer moves the throttle blade without the customer knowing it. So the engine torque is the same on both sides of the transition event. You don't want the customer to know this transition has occurred."
As a side note, the LH6 does not employ a six-cylinder mode due to the unique vibration associated with it. One of the greatest complaints with the Cadillac was the excessive NVH in V-6 mode, a problem that has been completely avoided by transitioning directly between V-4 and V-8 modes. Nevertheless, GM Powertrain has designed tuned engine mounts for multiphase engine operation. The idea is that if a customer doesn't look at the window sticker, he will never know he has DOD in his vehicle.
In our interview with Chris, we remembered that there was one other mid-sized utility in the GM stable, which uses a 5.3L V-8, the Buick Ranier. That vehicle is not slated for DOD, although it will have the new LH6 engine (minus DOD). Chris's explanation for the exclusion of DOD in the Buick Ranier is too long to print here, but is worth a condensed look in light of the next point we need to make. GM deemed that in order for the customer to truly buy into the concept of DOD, it must be absolutely undetectable. Even with ETC and tuned engine mounts, there was a distinct difference in exhaust tone between V-4 and V-8 operation. To mitigate this difference, a pressure-activated valve in the muffler adjusts the exhaust path to deliver an appropriate amount of noise reduction. It was found that such an exhaust system had packaging limitations that precluded its use in the Buick Ranier, which has a shorter wheelbase than the vehicles currently slated to receive DOD.
Fortunately, The Ranier and any other non-DOD applications currently getting a 5.3L LM7 will still benefit from the non-DOD version of the LH6, which will replace the LM7. The LH6's freer-flowing LS6 cylinder heads, oiling system upgrades and ignition system upgrades beat the outgoing LM7 to deliver 290hp and 325 lb.-ft. of torque (in both DOD and non-DOD form). It's also worth noting that the upgrade to LS6 heads required a new piston to meet program requirements for compression and power. Strangely enough, that leaves only the GTO in the GM V-8 line-up as having the older, lesser-flowing heads of the LS1 (since LQ4, LQ9, LS6, LH6 and LS2 all have some variant of the improved LS6 head). GM, can we have the LS6 head for the GTO in the 2005 model?
Operationally, the LH6 always deactivates the same four cylinders in the firing order (1, 4, 6 and 7). According to Meaghan, lifter design and pushrod length are the same for all eight cylinders, but camshaft lobe profiles are different for the cylinders, which are deactivated. (This seems, in part, to contradict the GM media website, which states, "...in displacement-on-demand equipped engines, half of the cylinders have unique two-piece valve lifters..." -this being an important stipulation for those wanting to swap camshafts.)
For hot rodders wanting to modify their DOD-equipped LH6s, it's important to know that the switching lifter has a lift limitation of 15mm (at the valve). The factory cam uses 12.2mm of that (about .480 inch), giving the LH6 a theoretical valve lift limit of .590 inch. It's worth noting that this limit is for the lifter; a different valve spring would almost surely have to be used at this valve lift. Interestingly, it seems possible to grind a custom camshaft, which would only provide increased lift and duration to the non-DOD cylinders (2, 3, 5 and 8), thus allowing higher lift with standard non-switching lifters in those cylinders.
Before our interview ended, we asked one final question of Meagher: With four cylinders working the entire life of the engine and four cylinders working for approximately half that time, is there any extra maintenance or any deviation of maintenance from a normal V-8? To that Meagher says: "The service life of the engine will be the same as normal current engines. There are a couple of reasons for not making the service requirement any different for these four cylinders. One would be to avoid any confusion; the second, quite frankly, is that it's not necessary."
PHR would like to thank Tom Read of GM product communications for arranging the interview with Chris Meagher.
Boy, they sure are proud of that accomplishment. I was just as enthusiastic when I disabled the DOD/AFM function the day after bringing my new 2013 home. Didn't have a choice from the OEM, so I took it upon myself. Too bad the cost for the R&D for this goofy stuff is included in the vehicle price. Nothing like paying for something forced upon you, just to have to turn around and spend more disabling it.
I posted the topic for people who were looking for detailed info on the the system, fyi, not because i liked or disliked it, maybe a good pin topic?
So simple and elegant that it you hardly notice the quart of oil burning out the tailpipe every 1000 mi.
Truly amazing that they put so much R&D into this stuff, bill us for it, and we never asked for it or wanted it. But, y'all are a bunch of dolts, so they need to decide for you what you really want and need. And the put their thumb in their suspenders and feel proud to have delivered this to you.
I am oft reminded of a Star Trek movie, in which they were steeling the Enterprise. The new Excellsior star ship was going to give pursuit, but conked out before it could barely get started. Screen shifts to Scotty saying... "the more complicated they make the plumbing, the easier it is to stop up the drain." This is so apropos to these AFM engines.
GM comes up with this stuff to appease the Feds. Some regulations are good, such as some of the safety items, but the CAFE regs have and will continue to change the products that are offered by the automakers.
Without going too far out on a tangent, I would submit to you that the CAFE to some degree, though we all hate it, plays a role in more than just fuel economy for the greenies. It definitely a tie-in to national security (we were sending to many $$ to the sand countries). So, while I hate it, I tend to be on board. Also, due to fuel prices, fuel economy once again sells cars and trucks. It's not exclusively to appease the feds.
Back to the matter at hand, do we think the AFM is still an issue? Or have they gotten reliability/NVH issues taken care of? My li'l 4.8 knows nothing of it of course.
plenty of topics regarding reliability and whatnot, haters and lovers, and opinions galore
I was hoping to start a thread of factual information about the system, some links to conversations on how to modify or delete AFM/DOD engines
http://www.texas-speed.com/p-717-dod-afm-delete-kit.aspx
if you Del the DOD, do the cam as well - there are numerous reports (despite what texas speed says) that you get misfires on DOD cylinders if you keep the stock cam with DOD mechanical delete, versus the software (PCM) tune-out.
http://ls1tech.com/forums/generation-iv-internal-engine/1569568-texas-speed-5-3-dod-delete-kit-help.html
an aftermarket or non-DOD oil pump recommended because, although they say it's the same, it has different pressure output.
5.3 LY5 has 799 or 317 heads
Scoggin Dickey and TSP sell AFM/DOD Cams (keeps the AFM/DOD), at this point I believe comp and crane will also grind you one. If you look hard enough, there are people with experience who state that AFM/DOD does not like high lift or steep ramping
would like to see the topic discuss technical aspects, maybe replacement lifters, Lifters were made by eaton and delphi.
Personally, I found the info regarding the cam specs to be the most intriguing, the DOD cylinders have a different grind than the full time cylinders:
196/201°
.488" (non-AFM intake valves)
.491" (AFM intake valves)
.488" (non-AFM exhaust valves)
.491" (AFM exhaust valves)
Not positive on LSA, but there was some guessing of 122.5° (or something very close)
196/201°
At this point, what I'd like to see more than anything is for Super Chevy, Chevy High Performance, GM High Tech Performance, Truck Trend, Trucking, Popular Hot Rodding, or somebody somewhere to swap out their truck's factory engine with AFM problems for a new GM LS327 crate motor and do a write-up on it.
The LS327 is essentially an aluminum-block LC9 without any of the AFM equipment and it may have a hotter cam and make a little more power. Win-win. I'd swap one in a heartbeat (no pun intended) if all of the bolts, brackets, pipes, hoses, and wiring looms would match up without more major surgery. And of course, Blackbear or someone would have to tune the PCM to recognize the new motor; hopefully you wouldn't lose the functionality of all of your other factory electronics (Driver Info Center, etc.) along with the swap and re-tune.
In other words, I'd like nothing better than to dump the factory AFM-plagued LC9 lump for a new, non-AFM-contaminated small-block Chevrolet V8--the best motor in the world, and what I thought I was getting in my new truck to begin with, and keep the rest of my truck (tranny, a/c, power steering, exhaust, etc.) just the way it is now. There's gotta be thousands of owners who would like to do the same thing--not everyone can afford a new truck, and besides, the new ones from GM still have AFM anyway.
    • Diesel or gas?  The 37s will obviously, drastically reduce mpg, but the gasser will take a bigger hit to mpg, and power.    I wouldn't sweat a gear change on a duramax at all, and unlikely on the gasser either. You're obviously not concerned with acceleration or towing, and the 10spd will find itself in the right gear without much hunting, if any.
    • I understand. It is disturbing to think a manufacture asks so much and gives so little in engineering support. This is not a GM issues, this is a greed issue and one the ALL practice.    My intent was not to remove the wind from anyone's sail but rather to point out the areas deficient so that they can be discussed with improvements the goal. But to do that you have to know the truth and what that truth is.    The commercial interest are honed in on a few select issues in which they control all the variables and are not forthcoming in the least with their customers about the details. Failure is the only thing that drives these people to improvement. One way not to fail it to manage public "expectations". The set a bar they can clear and put their thumbs under the suspenders with chest puffed.... Only the internal data tells the story fully. As we don't have access to that for decades then we have to generate it ourselves. UOA's with data that matters.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
