No Air HVAC Leason Learned
It all started when my driver side vents would go crazy and blow out hot air even though the passenger side was cold. I now know this was all due to a battery failure and replacement. At the same time I learned how to calibrate the actuators I also decided to change out my HVAC control module because it looked terrible from all the paint that had flaked off. Shortly after replacing the module I had a new problem occasionally where I would lose all air volume but I could still hear the fan blowing. I thought this was the door actuator so I tried calibrating a few more times with failure every time. I then removed the hush panel and checked all actuators while adjusting the module and they were all working fine. At this point I am stumped so I open the hood to investigate more when I found the entire HVAC system was froze up. I then came to a conclusion that my system is freezing the coils and that is why I was getting no air. A simple search on the web and sure enough a new control module has to be flashed by the dealer are the system will freeze up. Took it to the dealer and $100 later it is all fixed. A label on the module telling me it must be flashed would have been very helpful. Anyways, I hope this helps others with the same problem I have encountered if they change out their control module.
