'Interior Driver Assist Handle'
tenx82
they have this one on eBay but it says Grey. Idk if there is a Grey interior because my interior looks like a light Grey. Wicked Galaxy Note 3
Grey handle is for black or grey interiors.
Tan handle is for tan interiors.
so I'm ok if I purchase this? All trucks are the same Grey and black on the inside?
  • Replies 480
yes the grey is for black or the black and ash interior. The other one is for the tan interior.
cool cool cool, just pulled the trigger on the part. Monday I'm getting the remote start done to my truck at the dealer. $345 plus tax.
Late to the conversation but I got the handle a few weeks ago - according to my local parts guy, Cocoa Dune was the only color it was available in - luck for me. Took mere minutes to install, mirror image of passenger side with good anchoring into the bolt holes MotoMedic posted. Just pry off the old, plain molding, wedge this one in, line up the bolt holes and cinch it down.
Very nice. I'll be ordering soon. After the east cost recovers from the snow. All may previous shipments have been delayed 3-5 days. The USPS is FUBAR'ed right now. I had a package that needed to go 40 miles... Its taken 4 days already and still not delivered.
Tapatalk via Moto X
I can already see the commercial for the next generation of GM trucks
"...new to the market...now with driver side assist handle...professional grade..."
lol
so long
j-ten-ner
Has anyone gotten this and verified 100% that it IS the driver side A-pillar handle? Can we get an installed picture?
fshouttah2o - would you please post pics?
Photo or it didn't happen! J/K, can you post a pic tho. Thanks.
Sent from my Nexus 5
They've just refund and cancelled my order due to backorder.... WTF.. LOL
Yea Quirk parts just refunded mine also. I called my dealer and they said it was avaliable, but would have to be ordered. $42.95 5 days.
I've just order another one from my dealer.. $43, take about 2 weeks..
Mine got refunded also. Is yalls fault for ordering at the same time as me Hahah jp.
