'Interior Driver Assist Handle'
tenx82
Just ordered mine for $53 shipped to my door from gmpartsonline.net. Dealer wanted $70
  • Replies 480
I was told I needed to check that I had the bolts behind my current panel before buying this. Is that accurate, that not all have it already?
Should already have the holes for the bolts. I hadn't heard of any 14 model that doesn't. Check thru this post to make sure though. You can always pull out the topside a lil and peak down thru there.
Yeah, I didn't see anyone on here have any problems with it, but that's what the guy from Chevy told me, so I dunno. I'll pull it off this weekend and see what's behind there. I can get it for $45.
my dealer said they didn't have it and couldn't get it. Gmpartsonline has a problem with checking out. I can't checkout on two different computers or my ipad. ordered on gmpartsdirect. We'll see.
It will deploy but nothing will happen cus the bolts are holding the trim piece in place. Wicked Galaxy Note 3
I don't understand, Are you saying that installing this handle prevents the airbag from working properly?
I think he means, this will not fly off if the air bags are deployed, since they are bolted on.
My dealer parts guy had no trouble getting mine, although I had tried several places online. Paid $50.
the original one had a clip holding it so it wouldn't freely away when the airbag inflates. With this the airbag will inflate, but since this piece is held by 2 bolts to the frame the air bag won't go anywhere. Therefore my guess is that it will not serve is purpose lol.
Correct handle is determine by interior color, not model/trim level.
#23135699 for black/gray interiors
#23135700 for brown/tan interiors
I have the gray one because my truck's interior is black
the original one had a clip holding it so it wouldn't freely away when the airbag inflates. With this the airbag will inflate, but since this piece is held by 2 bolts to the frame the air bag won't go anywhere. Therefore my guess is that it will not serve is purpose lol. Wicked Galaxy Note 3
I don't believe GM would offer this part if it interfered with the airbag? Who knows? We need someone to install this and then get t-boned, and then report back to us if the bags worked ok!
LOL!!
    • Idler Pulley… from what I understand GM and Chevy trucks no longer have an idler pulley.. they stretch belts for both belts… I had mine replaced by my local mechanic last year on my Chevy Silverado 5.3 z71 LT.   They have discontinued using them on 2019 through 2026 as of a Google search.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
