Replacement Key and Remote
If they believe they owe you a set it should come ready to roll.
You know what I haven't even tried it to see if it is ready to go. Even if it's not ready I already asked my local dealer how much to program and they $45 and they need all sets.
Sent from my SAMSUNG-SM-N920A using Tapatalk
  • Replies 110
So --- they know you found the second set?
No I bought my truck like 2 hours away from where I live. Around me the trucks are super expensive.
There is nothing being worse being locked in a car.Having contact details of good locksmith provide relief in such a weird situation.When i got stuck in my car i call (*Sorry, no free ads*) and they provide me master key of my car.
  • 2 months later...
I wonder how much a locksmith charges to get you out of your locked vehicle . . . :rollin:
Has anyone tried the Amazon blanks on a '17? The guy at the dealer said it had to be a special laser cut key, but would most hardware stores have that machine? I bought the blanks for my '07 and it worked just fine. Same for my mom's GMC. But those weren't "laser cut" either.
I received two fobs and two keys, had an extra key made at dealer for free. I would like to have a key that will just unlock the door and put in a magnetic box on the truck, and put the third extra key in the truck to start. I hunt a lot and I always feel better so long as I can get in the truck. Any suggestions.
The key programming is easy. Just insert a currently working key, turn to run (do not start). Turn off, remove key and immediatly insert new key and turn to run. Done. Should start now.
There is a whole page in the manual about this.
  • 3 weeks later...
My truck will be here next week, we don't have GM dealerships here or any dealerships for that matter. Boy am I glad I told my guy to get a key and fob programmed. I must say I'm a bit intimidated by the fact that I can get locked inside my own truck. Sheesh
  • 7 months later...
I had a question that I could not find an answer to on this forum. I found the answer in the manual and figured I would post here to help others in the future.
My pickup: 2016 Silverado LT
My manual: part number 23133519
Information for Keys, Doors, and Windows begins on page 32.
My negotiating skills when purchasing my used pickup were not the best, so I left the dealership with only one key and one fob.
I purchased two blanks from amazon and had them cut at a local lock smith as most of you have done ($10 per blank, $15 per cut). I used the instructions previously posted in this thread to program one of the keys, and I received the message telling me that 3 keys have been programmed. I wanted to program the next spare key but I was worried about the limit of transponder keys that could be programmed. The answer to this question was found on page 45 of the manual:
"It is possible for the immobilizer system to learn new or replacement keys. Up to eight keys can be programmed for the vehicle. To program additional keys, see Keys -> 32. To program additional transmitters, see Remote Keyless Entry (RKE) system Operation -> 35."
I went a bit further to see if I would be able to program a new fob, too. Page 36 explains that up to eight transmitters can be programmed to operate with the vehicle, but instructs the owner to see the dealership for programming.
  • 7 months later...
  • 2 months later...
Gents, need some help here!
I lost my last keyfob last night and am locked out of the truck.  Are my only options towing the truck tot he dealer and getting a locksmith to get me into the vehicle?  Does on-star offer remote unlocking?
16 ltz 6.2
Yes, the My Chevrolet app allows you to unlock the doors, start the truck etc....   BTW, I also have the Chevrolet skill for my Echo Dot so I can start, unlock, etc.... by voice in the house!  ‘Alexa ask Chevrolet to start my truck” etc.....
Thanks for the reply.  Though I don't have the echo, I like the amazon link with the app... that's handy.
I was able to get a locksmith to create me a new key and fob :)  For some reason, I thought a Chevy dealer had to do this!
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
