I'll go through and check them all. What one do you think would be the culprit? The one at the switch?
I wonder if a connector isn't seated correctly.
The issue you are having after you changed the harness has been reported before in this thread. From what I've read on this subject the best thing to do is use original harness, new switch, and wire the signals and puddle lights separate. Just my .02
It has? I combed through this thread and didnt see anyone else with this issue. I must've missed it. Well that's disheartening lol
Can someone tell me the difference between 23154702 and 23154705?
23154705 will not fit on the trucks. My wife's 15 Tahoe with power fold has that switch. It will not fit on the plug in these trucks. I found out the hard way. 23154702 is the switch you want. I got everything to work with my old harness. You just have to wire signals and puddle lights separately.
I will confirm what txsierra14 said about the 705 switch. There was someone on another thread insisting that is the switch that was needed, so I ordered it and ended up blowing a fuse. It is keyed slightly differently, but I thought maybe it was just tight and forced it in. Bad idea.
I now have the 702 on order and will have to wait to get everything working.
Where do you guys ordered the switch 23154702? Because every GM part site said is on back order and they told me I need the VIN from a truck who came with that switch. Someone has an extra switch?
I got a note today from the place I ordered my switch (cheapestgmparts.com) saying that there was limited quantity, so I needed to provide the VIN from the vehicle that needed it. I just sent the VIN for my LT. On the other parts sites, when I put in my truck, it says the part fits my truck, so I am hoping that will work.
When I ordered the previous switch, they didn't say a word.
Ordered this morning, and got this email late today.
The item you ordered is on backorder from GM with no expected release date. Your order has been cancelled. We apologize for the inconvenience.
Thank you
The part number must have changed or the item is on a long back order for you to get that message. I have had it done to me too. It's been awhile since I got mine, try another vendor (Cheapest GM Parts .com?)
GMPartsGiant say the part is discontinued.
GM Parts East, part not available.
I did order from GANLEY CHEVROLET OF AURORA LLC.
I will post any problems.
UPDATE
When I ordered the part I had to include a vin number, and I was promptly contacted this am and told that this part will not fit my LT. I replied with I still want to order the part...
Edited by No Tyme
I got my switch today from CheapestGMparts.com and everything works as expected. I know this thread is for the smaller power fold mirrors, but I am using the power fold tow mirrors. I was following this thread because I was having issues finding the correct switch for my '14 LT.
Thanks for the help.
So, just for confirmation, please confirm my assumptions of your success:
Your truck is a 2014 LT ?
You added power fold mirrors ?
You installed the power fold mirror switch GM part # 23154702 ?
and that is all you did to get your power fold mirrors to work?
If any other parts were needed include them if you would. Your response will be greatly appreciated... Some have been posting that their turn signals and puddle lights don't work, and those are not my main concern. Thank you in advance for your response.
  • Yes, it is 2014 LT
  • I added the power fold tow mirrors
  • Correct, GM part number 23154702 is the part that worked. I tried another switch that was mentioned and it did not work.
The power fold feature worked by simply installing the mirrors, plugging them into the existing harness and installing the new switch.
I didn't need any other parts. My mirrors now have the following features working:
  • Power fold
  • Power adjust
  • Heated mirror glass
The 2014 LT truck will require additional changes to make the other features work. I hope to work on those when the weather is warmer.
Nick
So since this was the towing mirrors you added, it's safe to say that the power fold regular mirrors would work to right?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
