High Country "chrome" wheels?
so ive been checking my wheels and ive been looking around online, im trying to find out definitivley if my high country wheels are chrome alloy or chrome clad. ive found more evidence of them being chrome alloy. i still dont know for sure and i dont have the experienced eye to tell by looking at them. my common sense tells me chevy wouldnt put chrome clad wheels on their uplevel trucks. id like to know FOR SURE.
I'd hope the top of the line isn't clad, but the easiest way to tell is just to tap on them with your fingernail. If it sounds like plastic it's prob clad wheels.
No clad this time around on any wheel I think. You can tell by looking at the edges where they meet the rubber wheels. It would look like thin hub caps.
I like mine. I am wondering if the Goodyear LS2 tires will do okay in the sand. I will be taking it off road on the beaches of the Outer Banks of North Carolina.
Sent from my iPad using Tapatalk HD
LS2's suck everywhere
Sent from my SM-N900V using Tapatalk
I didn't think GM used chrome clad wheel/caps?? Toyota sure does. The new Tundra 1794 edition top of the line(very nice I might add) has a chrome clad wheel as well as the "limited" edition Tacoma. I'm sorry but that cheap crap belongs on bottom of the line models!
I like mine would of rather got the black 22in wheels but truck rides so nice im scared to mess with it
Yes they did, my 2012 wheels I still have a pic of in my sig had the chrome clad wheels and I had trouble with the plastic covers cracking by each spoke and or the chrome peeling off. That truck was on it's second set of wheels. Although I don't think the 2014's do but if you look at the edge of the wheel by the bead area you could see a gap between the cover and the rim.
My 2014 Expedition has Chrome Cladding as did my 2010 Expedition. My 2014 LTZ z-71 has true chrome wheels and I am very happy about it.
On an LTZ!! That sucks! It's that second lip I look for and you can feel it behind the spoke as well. If you catch it with your finger nail you can hear the plastic. That's how I discovered the two Yota's that way. Damn Dodge I think led this fake crap when they used some on their 20" truck wheels a few years ago.
have yall noticed that when gm produces vehicles it kinda seems the first few year models have good looking wheels and the later year models get the cheap clad or just ugly wheels?
All manufacturers start looking to cut costs on every product every year after a product is introduced.
Wifes Lincoln MKX ($50k SUV) has chrome clad wheels, my 2010 Sierra crew cab All Terrain with the 18's also had chrome clad wheels.
I just had my 20" wheels changed today and the guy said these were not chrome clad. He also said the 2014 rims are in good demand and I should recover almost all of the cost of my new wheels from selling these.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 648 Guests (See full list)
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
