2500HD leafs on a 1500
I have a 2008 z71 4x4 sierra. May upgrade in the near future, but regardless of if it's a '08 1500 or a newer 1500....is it possible to put 2500HD springs on a 1500? If so, are there any other upgrades that should be performed with that addition.
I'm sure you know what I mean.....it's like getting a huge motor and having crappy brakes. Just want to make sure I'm not missing something for the rear.
I currently have super springs (helper springs) in the back now....but I think I'll get quite a bit more capacity if I go with a 2500HD springs? Thoughts?
The springs will work, but the weak link would be the axle and brakes.
What is it your trying to do here? More height? Stiffen rear end for towing/hauling?
Primarily stiffening the rear for more hauling. Didn't think adding more leafs (or bigger ones) would help me with towing so much. Truck squats pretty easily with 1200 or so pounds in it. I don't really need the capability of a 3/4 ton payload capacity.....it's a nice jump......but I'd to get more payload out of it without killing my truck. I use it for everything.....I mean everything....but even a load of firewood is a bit much for it. I know there will be a bunch of folks that will brag about how much they can put in their 1/2 tons, but there is a reality factor too. stepping up to a 3/4 ton is significantly more $$$ too. I may do it, but a few modifications would be a bit cheaper. So can I get a heavier axle on a 1/2 ton.....if it's needed?
Not too much help here but I can tell you my father installed 2500 leafs on his '98 Z71 to help with towing his heavy boat. The boat was within the towing capacity but he didn't like how the truck felt when he towed, he liked the stiffer feel with the 3/4 ton leafs. He also loaded it up with a full bed of wood quite often as well. Truck has 235K on it now and is till kicking.
500 lbs difference is all that is between a 1/2 and 3/4t,,,,get helper springs and drive it ,,,,dont think to deep into what ya want ,,,,imo
Helper springs. Add a leaf kits. Check out oversized jounce bumpers made by Timbren. Switch out with 2500 springs if you can find some. Any of these are options.
Sent from my LGL86C using Tapatalk
If it was only 500 lbs difference in a 1/2 ton vs 3/4 ton payload...trust me, I wouldn't be thinking about this at all. I agree with you.
The difference between the 1/2 and 3/4 (at least back in 2008) is just shy of 2000 lbs.
Sierra 1500 1947 Sierra 2500 3892
You cannot legally increase the manufacturer's payload amount located on the yellow and white sticker inside your driver's door jam. If you haul overloaded-you will leave yourself open to lawsuits, both on a criminal standpoint and a civil standpoint if you have an at-fault accident. (Yea-I know nobody ever has an accident-right?).
If you have an at-fault accident and you harm or kill someone you will be sued civilly and your life will change forever.
Is it worth it? Dude...buy a bigger truck.
Wow.....if people get a hold of this, it's going to put a lot of 'add a leaf', air bag, etc., etc., etc. companies right out of business. Basically modifying a truck is out of question. Gotta go by the yellow and white sticker. Can't get my head around the magnitude of this. Any modification will be just for looks.
You misunderstood. You can modify your truck.....but you can't exceed payload.......legally-without ramifications should something happen. Another interesting conversation would be calling up your insurance agent and telling them your ignoring the manufacturer's recommendations as regards to the capacities of the truck on a regular basis, and seeing what they would say.
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 843 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
