Exterior Graphics
TTU19
I was originally going to do something simple, like a black pinstrip on my red Silverado.
Anyway, my wife says I should do something a little more "unique" and or "wild". She mentioned something like how the Ford Raptor has.
Have you seen any kind of interesting, not TOO crazy graphics? I've seen the sort of upside down hockey stick. I dunno what to do now, HA.
  • Replies 37
Yeah, I understand that, just thought I'd reach out and see what others have done or saw. Just trying to get ideas. I dont know what I want to do right now. Thanks..!
There is a dealer in town that pin stripes every car they sell it seems like. You can always spot the vehicles from them. As stated above it's personal preference as to what you want. I'm not a fan of pinstripes as they tend to peel to easy and look bad over time.
Pinstripes and graphics are from the late 80's. Please do yourself a favor and don't put them on your 2014 truck lol
Find a local shop the does vinyl wraps. They do alot of boats in my area. Talk to them they will have ideas and make you anything.
Here is what I did to my 2007 with my vinyl cutter. As you see in my Avatar I am working on something similar for my 2014 and recreated the 4x4 logo on the bed to match the color of my lower door graphics. Waiting until warmer weather before I tackle the bed stripes to match. I usually change it up every year or so as I get bored way too easily.
If I add a pinstripe, they will be painted on, no tape.
Wow that is ugly
To be honest I don't really understand what it is suppose to be. I could see if you did the lower third of the truck all the way around but a black box?
