First Oil Change?
Brock Samson
Should I run until the computer tells me to change the oil, or should I have it changed early on for engine break-in around 1000 miles or so?
  • Replies 75
I changed the oil on my 2010 GMC Sierra 5.3L when it had a little over 800 miles on it. I wanted to let the motor break in and change the oil due to the assembly lube inside the motor. I've ran Mobil 1 and an AcDelco PF63 oil filter ever since then.
Technically I don't believe you need to, GM engineered them pretty well. I just wanted clean fresh oil that way I know what is truly in my engine. Also because I'm anal about this kinda stuff.
Daniel
I changed mine at about 1500 miles and sent an oil sample to blackstone labs, the report showed some iron and silicone, but nothing major. I'd suggest that you change it around 1000-1500 miles.
1st - I bought the truck from an out of state dealer. Are the "free" oil changes for the first year good for any GMC dealer? Or does it have to be through the dealership you bought your car?
2nd - Is anybody here doing their first oil change at around 1000 miles, as has been the practice in new cars for a while? or is that a thing of the past? My truck is getting close to 1000 miles now, and that feeling is kicking in that I should change the oil.
3rd - Synthetic oil. I know everyone has opinions on this, but has anyone actually seen improved MPG after switching? Any benefits other than longer oil life and longer between changes?
Thanks in advance.
Thanks in advance.
You will not notice any substantial MPG differences between conventional and synthetic oils. In fact, I thought to achieve the 0W20 weight it had to be partial synthetic anyway, so there's not really any "switching" involved. Besides, GM spec'd Dexos 0W20 is advertised as "High Efficiency oil", so I bet that all brands/types will perform nearly identically.
I'm approaching 5000 miles and haven't changed my oil yet. I still have like 40% on the OLM. I'm probably going to bring it in soon though as that seems like a lot of miles on new oil.
Any dealer can do the free changes - it's a GM offer, not a dealer thing.
Changed the oil and replaced with magnetic drain plugs at 500 miles on my camaro and 750 miles on my silverado , glad I did cheap insurance and it was pretty dirty/dark
Ryan
There is a lot of information on this sight pertaining to your situation. I suggest you use the search button because several users have even sent their oil off to Blackstone for analysis and from the findings, I would suggest not going the full extend of what your DIC is telling you, at least not during break in anyway.
Changed the oil and replaced with magnetic drain plugs at 500 miles on my camaro and 750 miles on my silverado , glad I did cheap insurance and it was pretty dirty/dark Ryan
That's a damn good idea, I will pick one up tomorrow. Do you remember if they were anything special on this new motor or if they are the same old 14mm used in prior years?
^ I changed the drain plug too, IIRC, the plug was M12x1.5.
Thank you
Are you sure it's an M12x1.5 pitch?
Another user on here got information from another drain plug source claiming that it is m12x1.75 pitch?
It works asuve3u6.jpgRyan
Do you remember which size plug you got Ryan?
As short a threads as it has to screw into, a 1.5 and 1.75 may interchange but I dont want to take a chance on damaging my oil plug threads.
I just called dealer, the 5.3 and 6.2 use a M12x1.75x25
Just double checked, the thread is indeed M12x1.75, I bought the plug from a local Autozone.9a9ebaqe.jpg
I did my own oil and filter change at 750 miles, drained oil was dark chocolate in color with a high concentration of metallic particles when stirred.........didn't need an oil analysis to see it needed to be changed.
    • Still $4.50 85 oct.
    • B07 has a lot to learn. New kid on the block. You sound like a still wet behinnd the ears youngster by the way you respond, calling out someone  and you know nothing about him. Look around this forum at Grumpy Bear input before you spout off.
    • Is it what you were talking about ? https://www.lislecorp.com/videos/lubrication--tire/19912-multi-application-oil-funnel-14-pc
    • Good thing my wife doesn't frequent my automotive forums, she might get the idea of strapping me to a handtruck and leaving me curbside for the pickers day before garbage pickup!
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three or four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
