Aftermarket LED Taillights
I am looking at these: http://www.ebay.com/itm/221475734000?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_3206wt_1238
Anyone have a set? Working OK?
I prefer the OEM look. I see Anso has a similar set listed on their website, these seem to have the same tag on the back and are identical. Sorry it's an Ebay link that will expire, I could not find anywhere else.
  • Replies 576
Nevermind...I found the info that these are Anso made by Eagle Eyes. Took while to trudge back to page 3 or 4 to find that. Sorry for the redundant post!
Works fine here:
Yes, it's a mobile link. I didn't notice that earlier. It only works for mobile Ebay. Clicking on it from a desktop browser doesn't work.
Just remember you most likely to have mositure or water issue unless you improvide it better
With what? The taillight kit or headlights? What brand has sealing issues?
A lot of the cheap decent aftermarket parts. I have bought taillights from anzo, sypder,autotune. Everyone of them i had issues. Only ones i havent tried is gorecon but they re 800 and im all set.
Looks like WINJET LED tail lights are back in stock. HERE
I like the design, anyone running these?
If you go back a few pages youll see the pics of my truck with them. They have held up great over the past couple months. We've been getting a lot of rain here in Texas and they have not shown one sign of leaking water or any other defect.
Will sierras taillights fits Silverado? Like the one's above? From eBay
Don't think so. I think the Silvy lights are a bit squared off around the edges compared to the Sierras.
They won't. The silvys have around a 45* angle at top and bottom and the Sierras have a curved top and flat bottom
There it is, my buddy Mike will come in with the numbers to prove it. :rollin:
    RyGuy43
    RyGuy43
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
