Orange Peel on the paint?
kenotic
While filling my tank today I notice that the paint right in front of the rear wheel wells looked to be orange peeling at the bottom. It is on both side, but it still does not seem to be normal to me. Anyone else seen this?
Orange / rust specs on my tailgate. (Color is Summit White) so it sucks!!! Ugh.
Sent from my DROID RAZR HD
orange peel or rail dust? 2 distinct different issues
Some orange peel is normal. I do not think you will find a new vehicle that does not have some of it in certain areas. Some colors show it more than others.
As for rail dust, use a clay bar to get rid of it.
the orange peel is actually a chip resistant coating along the bottom edge of both sides. it's on every 2014.
I guess this is a little more pronounced than normal orange peel. Is it normal.
y6a3upu7.jpg I guess this is a little more pronounced than normal orange peel. Is it normal.
Yes normal, mine has it too.
That is the stone guard film, not orange peel.
Yes, this is gravel guard spray under the paint. It has extreme orange peel appearance, but this is normal. GM used it more extensively in the past. I remember my father's 1980 Cadillac Coupe de Ville had it along the bottom on both sides.
yep. This is to protect the paint from crap getting flung up at the rocker panels.
yep - i think mine runs the entire length of the rockers. my '10 did not have it and i really missed having it on my truck. i was happy to see it when i bought the '14!
Yeah,the stone guard sure does look like a really bad case of orange peel.
My old truck ('98 K1500) had a way better paint job than my new one. There is definitely quite a bit of orange peel in the paint. Not sure if it's this new water base crap causing it or just a bad paint job. Doggone those robots anyway!! :)
  • 3 months later...
I did not notice the orange peel on mine when I first bought it and it has been pretty dirty until I got it detailed a couple weeks ago. The owner of the detail shop pointed out all the orange peel to me and said the paint job would be considered unacceptable. Not almost acceptible, baiscally totally unacceptable. Should never have gone to sale the way it is. What's worse is I just noticed what looked like a like a little knick from road debris and I touched it with my finger nail only to see that the paint just flaked right off. I now have a spot about the size of a silver dollar already where the paint is flaking off.
I am pretty livid. Waiting to hear if others are having paint peeling off yet. This is the absolute worst paint job I have ever seen. I touched the scratch with my finger nail and the paint is ridiculously thin and actually flakes right off. I'm not sure what to do at this point.
The detail guy also said there was some kind of marking material that repair shops use and it is only seen on a vehicle when it has gone for repairs...but I bought the truck brand new.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 646 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
