Yep, I am going to have to take my truck in for this repair. I take it will take 2-3 days to complete. Add paint repair to the insider driver's door that bubbled up and is exposing the primer. Guess I will be driving a rental for about a week. The sad thing is that I have to drive 160 miles to get this repaired. The good news is that I will be in a city where the repairs can be done for a couple of weeks. The scary part is that they have to remove the bed and other parts in order to make this repair.
What can one say to that? Doors already peeling!!
Silverados corrosion protection measures provide superior defense against elements in the environment, whether driving through farm fields, on construction gravel, or down a snow-covered highway, said Mark Yergin, engineering group manager, General Motors Corrosion Engineering and Labs. The new Silverado is our strongest truck yet, affording us the confidence that the truck will continue to meet customers needs throughout its life.
Additional 2014 improvements over previous models include:
All new body structures designed to minimize the potential for corrosion
Improved hem flange sealing on the doors and hood, and additional underbody flange sealing help keep the joints of the truck dry, discouraging deterioration that might occur from moisture
***Extensive and improved chassis corrosion protection that enhances the trucks appearance and lengthens the life of underbody components
Anti-chip protection on the lower body side for extra protection from stones or gravel.
http://media.chevrolet.com/media/us/en/chevrolet/news.detail.html/content/Pages/news/us/en/2013/Sep/0905-silverado.html
Edit: the strange thing is, I haven't been able to find this same info about the 2014 Sierra. On GM's media site I could only find it on the Silverado.
http://media.gm.com/media/us/en/gm/news.detail.html/content/Pages/news/us/en/2013/Sep/0905-silverado.html
Edited by 14LTZZ71
  • 6 months later...
Well took my truck in today
Dealer just pealed some of the flake off and spray painted some of the rust.
Not very happy!!!
What can I do now??!!
I just traded my perfectly good 2013 Avalanche for this exact reason. Every time I changed the oil and looked at the undercarrige I got sick to my stomach. Not just the frame but EVERYTHING under there looked like it was 75 years old. I saw the results of the "fix" on other trucks, it was a mess.
Not very happy!!!
They did the same thing to me. I'm just living with it at this point. I don't have time to keep fighting with the dealer over it and taking my truck back in for service. I'll probably end up trading this truck before it becomes a problem but rest assured GM, I will strongly be looking at other manufacturers.
My 2007 did not have an issue with this so sometime between 2007 and 2013 there was a production change in the quality of the wax coating process.
Does anyone think this issue from the factory may have stopped after certain build dates?
Not really unless you want to pinpoint a year between 2007 and 2013 where basically every truck, Suburban, and Tahoe after that date will have rust issues like this. Unfortunately this just seems to be the new standard of quality on these trucks. It's not just GM though look under an F150 when you get a chance...they have just as much rust in some cases but they paint their frames, not coat them in wax.
In my opinion this is something to keep a close eye on going forward with ALL make and model trucks, not just GM.
Compete bull$hit
Is this an actual recall or whatever in Canada?
Some trucks have the wax falling off in sheets and there's a recall of sorts for these trucks. However, all of them from what I've seen will exhibit early signs of rust over previous generations of these trucks.
Not sure what to do
No recall based on my vin
So I guess I'll fix it myself
Thanks GM!!!!
If you seen how they "fix" them, you'll be glad you did it yourself
Does anyone actually believe this?
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,214 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
