I just dropped off my GMC 2500 HD at the Chevrolet dealer for same issues. Shocks rusting...bolts rusting and the frame as well. They said they sprayed the bolts with
WD40 {I could have done that} and said that I can use Fluid Film If I want so will head to Lowes for a case. The frame they said will be done by a certain procedure
per factory and said they will paint the frame. Don't know if they replaced the shocks.... but will post if so. Truck bought in December and has 1600 miles so far and
is not a DD. Has been driven in snow and was put through a touch less car wash {It does fit} 7' is close on a 2500 HD and was under carriage washed 4 times so far.
Mostly done by hand as I'm a detailer for 40 years but hate the cold and has to be done outside. Will pick up tomorrow and will post results on frame.
Sierra Boy
Well,
Picked up the truck last night and they did not replace the shocks...they just sprayed them with WD40 and the bolts they did the same. The frame however they scraped all the loose wax and wire wheel the surface rust off and treated the spots and re-applied the factory coating throughout the entire frame. Looks really good {for now}.
What can I do with the bolts if I get new ones and want to either plate...powder coat to keep frtom rusting?
Sierra Boy
This stuff should be showing up on my doorstep today: https://www.daubertchemical.com/store/product-list/corrosion-prevention/nox-rust-x-121b
I'm hoping I can spray it right over the rust and don't have to do too much surface prep. Like Rustoleum or somet
GM part no. 12346501 or AC Delco 10-7014 is the nox-rust x121b called in the GM spec. This is a spray can for touch up that goes on and leaves a black/wax film behind. Any GM dealer can get it,they may not stock it. The list price 13.84 a can they may want shipping mine did not. NO way will my truck go to a body shop
I'm hoping I can spray it right over the rust and don't have to do too much surface prep. Like Rustoleum or something.
Did you get a chance to try it out yet? I'm about to order this too so I am ready to tackle any start of rust.
No it's been raining here and I've been busy. Maybe next weekend I can find some time. I was going to look into getting some ramps to make the work easier too. Whenever I do it I will take some pictures and post them.
O boy, following, no issues yet
You need to crawl under your truck more haha
So far I'm good, only trouble spot is in one of those round tube cross member over the rear end, but I think I did that with a pressure washer blowing the crap outta there, haven't figured out what to do about it yet
How far did they tear everything down for those who had it addressed correctly?
Tear everything down? Addressed correctly? They give the lot boy a wire brush and a putty knife and have him go to town. Then he sloshes goop all over the under side of the truck, inside the wheels, cables, wires, brakes, and maybe, you'll get some on your nice paint job. I've seen it "addressed correctly" first hand. No thanks.
My dealership doesn't have a bodyshop so they have another place do their body work. The shop they use has a great reputation, I've seen some of the work they've done. In don't think they would make a mess and expect me to accept it
Then you should ask them how far they are going to tear everything down and correctly address it. It's worth a phone call.
I did do that when I took the truck there, he said he would pull the bed and cab to do it right. He said that he gets the feeling they want him to put it on the lift and just spray bad spots. He can only do what they tell him. That's why I'm asking for people who have been through this already on their experiences.
Edited by depogrog
If you get him to pull the bed and cab, you should be playing the lottery every night. Cause you be a lucky son of a gun.
Edited by steelcity
Here's what mine looks like.
LOOKS LIKE JUNK.
I bought this truck beginning of October 2013. So about 19 months old now.
2014 GMC Sierra All Terrain.
As somebody who works FOR a company that does the marketing for GM, I am starting to get VERY sceptical when GMC is launching slogans like "Precision Truck Event" and "GMC, Precision Matters", etc.
Look at my shocks for example! Seriously?!
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
