Opening Headlight without Cutting?
Hey guys
I was wondering if anyone had any clues on how to open a 2014 sierra's headlight without cutting around the lens.
I've done a lot of research and come up empty handed. I've considered baking the headlight but I am uncertain if this is possible with the LED's and wiring unable to be removed?
I want to paint the Chrome housing of the headlight black, I think it will really make my truck look different from most '14 sierra's
any tips will help
Thanks
  • Replies 133
The only write up I've seen is where the guy dremel's around the lens. Not sure if there is any other way.
I Bake all my headlights in the oven.. 275 degree for 7 minutes
Its the only way I've seen that's demonstrated, trying to avoid cutting it open (seems like a lot of work and big mess)
Do you think by baking the headlight it won't damage the LED's and the wiring to them? This would be my only concern doing it this method.
Nope, when baking it, make sure to leave everything in there ,even the dust cap cover to prevent moisture build up inside the headlights.... Only remove those little screws that holding the headlight housing and the lense together before baking it...
Just wanted to let you guys know that I baked my Headlight and it did work. I have them open now and gonna paint the chrome
pics?
I will post pics once their completely assembled.
I put them in at 220 for 8 in just like block8head said, worked fine. Used a screw driver to slowly pry the sides off the lens. In total I had to reinsert the first light into the oven 5 time, first time doing it. Second light was only 3 times, it really wasn't that difficult just a little patience.
Awesome this is great news, seems like the black sealent they used was pretty hard, last thing I wanted to do was cut the headlights up.
At first I thought the glue was gonna be too hard to do it, but it does take a little persuasion and some force to get in there. Extremely happy with the result i think it looks so much better than with the chrome. Also very happy that I didn't have to cut them everything went together super easy and like a glove.
Let me know what you guys think, and ask away if you have any questions.
Before
After
I was thinking the all terrains should have a black headlight housing the other day and it looks awesome
    DriverTires
    DriverTires
  • Who's Online   5 Members, 2 Anonymous, 1,420 Guests (See full list)
