Opening Headlight without Cutting?
Here's pictures of my project assembled. Hard rains here all day yesterday and I had no water, fogging, or condensation!
Man that looks sick. I think you convinced me to do mine.
  • Replies 133
I really like the look of your truck Dan. :thumbs:
I'm just not willing to give up 1 lumen in either my headlights or DRLs for tint. :nonod:
Update: I very carefully ground the fused ends off of the tabs to separate the pieces. FedEx is bringing some new stuff for me today, I scuffed the chrome trim and painted it satin black. I'm excited to see the new look. Still undecided on whether or not to do the grill at the same time.
I have a '14 All Terrain crew, white.
How did you re-assemble the lenses to your newly painted trim after grinding down the tabs?
  • 4 weeks later...
OMG! this looks AWESOME! I want to do this so bad to my truck! if anyone with a black Sierra beats me to it, please post/send me pics!
  • 1 month later...
sorry to necro-bump, but MAN this looks awesome. I've got a feeling i'm going to be in way over my head but I'm ordering some new bulbs and am definitely going to get this started ASAP
thanks for posting everybody
+1 I would also like to know!
At first I thought the glue was gonna be too hard to do it, but it does take a little persuasion and some force to get in there. Extremely happy with the result i think it looks so much better than with the chrome. Also very happy that I didn't have to cut them everything went together super easy and like a glove.
Let me know what you guys think, and ask away if you have any questions.
Yeah. What did you do/use to re-seal them when assembling the headlamp housings, i.e. sealant? I'd be concerned about condensation afterward if not properly sealed.
TurboNV8's,
That's nice Work.
Looks tight against the white body.
this thread really makes me wish I'd gotten an SLT just for the running lights alone :freak:. With the SLE's we've just got more chrome where your DRL's are, i'm trying to imagine it black but not sure if it will be too much or not
also, any recommendations on lighting upgrades while I'm down there? HID's? vled LMZ?
Correct me (anyone ) if im wrong I read on another thread a SLE owner upgrade to the SLT headlights and seem to work. Not sure if he ran to any major issues.
  • 4 weeks later...
For those who have baked their headlights to open them, did you need any extra sealant? Ie would it be a good idea to order some OCI rubber butyl glue like what TRS sells so that I can make sure that the headlight gets resealed properly or should I be fine reusing the OEM stuff?
http://www.hidplanet.com/forums/showthread.php?35908-Lightwerkz-Global-Inc-OEM-HID-Projector-Retrofits-Angel-Eyes-Painting-HID-Systems-Technical-Support-amp-More!&p=728993&viewfull=1#post728993
I found this on hidplanet a while back. Post #1643 and #1645. Lightwerkz uses the Koito butyl rubber sealant to seal them up. On the other hand, I've heard it's hard to work with too.
Fastheadlights Phil likes silicone.
I'm waiting on some switchback led strips that I ordered that I am going to mod into the upper and lower chrome areas and then paint everything black including the side marker lens. Will start a dedicated build thread with finished product.
I baked my headlights this weekend and now I understand why Phil at Fastheadlights cuts them open. It was a very tedious process to get the lenses off first. Then clearing the perma-seal is another story and I can't repeat the words I used. I lost count how many times I had to put the housing back in the oven to soften the perma-seal enough to scrape it out. I used the butyl from TRS to put the lights back together. It seems like some of the guys that have done this either just simply had lights that weren't as much trouble or they didn't let on that these lights kicked their buts.
The Retrofit itself was pretty simple, although the brackets are printed and crack easy. I need to send some pictures to Phil so he can see what I encountered. It was not a big deal, I mixed up some epoxy as an added measure to ensure the brackets would stay attached to the projector mount.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
