Once i get done with the interior on my truck im going to finish the exhaust. I was looking at Magnaflows cats, you can get them as a stand alone weld/clamp in or with all the pipe from the manifold to where they clamp on to the factory exhaust/cat-back, and come in stainless. Kinda pricy for my truck but i like the fact i can just bolt them in and go.
I was thinking of going with those until I looked at the price. Lol! First I considered a whole new Y-Pipe, but I don't really feel like dealing with that, and it's almost $400. I found some converters by Walker for around $93 a piece. Probably just get those, and have the shop weld them up. Probably have $250-$275 in it total.
Are your cats bad? For those internet monies I would choose a tune! I would love to tune for 91+ and smooth out the tranny.
I'm not 100% sure. The truck seems like it's down on power on acceleration compared to when I put the motor in. Then there's the flashing engine light issue I get every so often on the interstate. Another member here said once they replaced their converters the flashing engine light went away. I figured between that, and the mileage it's probably a good idea to just go ahead and replace them.
Here are a few that I've found so far.
Edited by Daryl Z71
I replaced the entire y pipe and the o2 sensors and I think my issue was more with the sensors than the cats honestly
See, I replaced all four of the sensors last fall, and the truck ran a lot better. Now though it seems like it's sluggish again. The cats are the only thing that are left to replace. I'm not sure if that's the issue, but it's the only thing left.
Sealed the extended cab window shut, and added some sound deadener to the door panel.
I've been eyeing up these seat covers for a while. They're probably what I'll go with when I decide to buy.
you looking for them to be waster resistant or just fitted and tough?
check these out, supposed to be tough. I been thinking about ordering them myself instead of having the seat redone.
https://www.decorauto.com/product/cordura/
Those look nice too. I just want something that'll last and fit good.
Why more springs?
Sent from my SM-G920V using Tapatalk
More stability, and to prevent it from sagging so much in the rear when I haul my trailer and fourwheelers.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
