What was the beadlock issue? I have a few that are starting to show surface rust. I called to see if they have replacements or offer them in stainless and they said no. I googled and found some old threads on different forums saying they offered replacements. So I am a bit confused. Not a big deal, but would like to replace them if possible.
I had issues with my "real" Method 105 beadlocks, at one point they offered two hub bore/center cap designs. I ordered five, and two were lost in shipment when they came in they were different and I had already mounted 2 of them since I had them and when the new wheels showed up different. They replaced them! Only thing that sucked was unmounting and remounting the tires.
From what I know even on the faux beadlocks the ring bolts are removable...take them off and find replacements at a hardware store?
Edited by AaronArf
They are replaceable, but I don't want to cut down 100 of them ;)
hi all - want to upgrade tires/wheels. State of Maine has a strict tire past fender law.. dont want to add flares. she sits stock now with 18's. wanna stick with 18 and add more rubber. she sees a lot of bad roads, dirt, mud, snow and Prius eating potholes. Dont want a BRODOZER- just want to fit as much tire as i can - so i guess my question is this - how much can i stuff underneath and how, while not having to flare - level/lift , offset.. know what I mean? thank you in advance..
Wish I went 10". Bought same wheels, but 9" 0 offset. They haven't came yet so I'm really debating returning them for the 10" wide.
I have 9.5 wide and 0 offset running 12.5 wide rubber. They stick out about 1.5" in the rear and just over an inch in the front
285/65r18 and 275/70r18 will work without a level but the 275 may rub the carpet. Either will look overstuffed on a stock truck. Levels are cheap and easy to install. Stock 4x4s look like 2WD without a level.
20x10 Hostile Styker wheels with 275/60/20 falken wildpeak at3 tires and RC leveling kit.
Do the spokes on your wheels go in the same direction on both sides?
Yes
This truck looks perfect. All these Method Race setups are giving me second thoughts. I love Methods but I have a hard time justifying their price vs Pro Comps in a similar size. The Method 17x8.5 / 0 offset Mesh wheels weigh 27lbs and run about $800/set. The Pro Comp 17x9 / -6 offset 5045 series weigh 24lbs each and cost less than $500/set. Can anyone convince me that the Methods are worth that much extra money? Are they really of a noticeably better build quality than Pro Comp wheels?
4WP has a sale going on methods right now. 15% off and free shipping. I could have saved some money!!
http://www.4wheelparts.com/eSearch.aspx?Ntk=primary&Ntt=Method+Race+Wheel+Instant+Rebate
Looks really good man. I love chemical guys, I use a lot of their stuff [emoji1303]
What are yalls thoughts on these Black Rhino Madness wheels on a Tungsten truck?
Those are definitely different but something about them I think they look effing sick. I say do it man pull the trigger on those
Appreciate it. Just ordered their TORQx orbital. Try and remove some of the hairline scratches from the car wash.
    KJEK
    KJEK
  • Who's Online   2 Members, 0 Anonymous, 465 Guests (See full list)
