Pulled the trigger, XD820 20x9 +0 wheels are on the way. Going to run a 305/55/20 tire on them.
Got my new shoes on today
-eibach leveling struts/shocks 1" front. -1" rear
-20x9 et0 kmc xd 128
-hankook 305.50r20
Just the very slightest rub on pass side in reverse at full lock.
Sent from Galaxy S7 using Tapatalk
Got the truck all cleaned up today and took some driveway pics. I'll try to find the time to actually take it somewhere and get good pics but this will do for now. Skid plate pics as requested below.
C45B0C1D-2280-44F1-9E67-DF2F036FB71D_zps
907DF60F-5F2E-458A-94C7-820B28C96498_zps
A6B8B7CE-F332-4F6D-A001-C75AC0B73E55_zps
BC5A95D5-AFF6-466F-B217-0F9A3628F0F9_zps
I also got my spare mounted under the bed in the factory location. Since the hub bore on the Methods is larger than the factory wheel I made a steel plate to slide over the hanger and support the whole hub. Lined the wheel side with adhesive backed uhmw film so it doesn't scratch the wheel.
B20B0B51-3670-49B6-92E8-CDFE380854BE_zps
4DA4043A-D4FD-49E6-B837-09B4778339ED_zps
8631C7BB-DF11-44B3-8D0B-9BF89EFE286A_zps
E1048656-41B3-4385-ADB2-E601EF5159B3_zps
99D9A350-F3BB-4610-9E0A-4D17BA27BE0B_zps
Skid plate pics. Sorry for the insanely long post!
6B9F0BA2-966F-4681-BE5B-81F084466983_zps
5BB7C3A9-BFC3-4BA3-BE94-827EC72E879C_zps
2A921872-4882-451E-AED3-04E096368B44_zps
6639CDD0-49E8-4A3A-A509-D37D8EED1259_zps
C7129684-1275-4675-BA67-8B4856FCFB0D_zps
  • Like 9
Sharp truck stroker! Skid plate looks great on there. Trim the bottom of the fender liners off and it will look even better.
Thanks! That's next on the list actually.
One more just because
820214EB-4129-4157-9397-8476593940F3_zps
  • Like 3
Stroker your setup is clean AF! This is definitely one of my favorite trucks on the site. Do you have a build thread?
Congrats and well done!
Sent from my Nexus 6 using Tapatalk
Thank you very much I'm so happy with how it turned out. No build thread...yet...guess I need to condense everything into a build thread but I'm pretty much done with it for a while.
Where is everyone getting there tpms sensors/stems from?
Moved mine from my factory wheels. If that's not an option for you then ebay or Amazon. I've seen sets as low was $40 for OEM.
Sent from my SM-G930V using Tapatalk
Love me some methods! You're clearance looks to be way more than mine, though admittedly i only got 1.8" out of my Bilsteins. What was your height after the Kings?
I did this as well. The decent sensors are expensive for what they are, i'd just use the ones from factories.
Amazon. These are the ones I bought but it looks like they changed part numbers and price by a lot. Got them cheap at the time. https://www.amazon.com/ACDelco-13581558-Original-Equipment-Monitoring/dp/B00O9H0QIG/ref=au_as_r?_encoding=UTF8&Make=Chevrolet%7C47&Model=Silverado%201500%7C491&Year=2016%7C2016&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive
I'm sitting within a 1/4" on all four corners, tad over 40" ground to fender
Question for you. When you upgraded to the kings and new UCA did you also replace your lower balljoint?
Nope just the upper is necessary unless you go full mid travel which pushes track width out in the front but that replaces both upper and lower arms. Angles still look great on the lower arm and the truck only has 3500 miles on it.
B3185A4E-3018-4FC0-B12B-F3C35D64AAF0_zps
Edited by 89stroker
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
