Is anyone out there running a 20x10 with a NEGATIVE 19 offset on 33x12.5x20 mud terrains? I have the fabtec 2 inch leveling kit. Ive looked at several trucks on customoffsets website and they claim to be able to run a negative 24 offset and only slightly rub. Is this true? I can deal with a slight rub, but nothing major. I really like the look a negative offset wheel gives. Im leaning toward Hostile Knuckles, or Dropstar wheels. PLEASE SOMEONE HELP!!!!!!
This will rub bad. I have 20x9 0 offset wheels with 33x12.50's on them and a 2" level and they rub the fender in reverse. I was able to zip tie the plastic back and take a heat gun and mold it in some and it still rubs a tad, no way you're getting that setup in there without a body lift or suspension lift or major metal cutting. I can think of his username right now, but someone is running a 20x10 -24 offset with 305-50-20's which are shorter than the 33's and still had to trim metal.
zone 3.5 inch combo 2 inch level 1.5 inch body lift rims motto metal 20x10 -24mm tires 305 55 20 nitro terra grappler g2 not shown but are installed now. i had to get new tire these in the picture are atturo trail blade XT's they are crap tires. they where unbalanceable. i had to send them back. i will take more pictures after i wash it. it sits level and i love it.
hey chris, does this wheel n tire combo rub at all with the combo lift?
ok thanks! looks like I will need to order a zone 1.5 inch body lift. Do you think a 20x10 with a -24 offset and 33s would clear with the zone 1.5 and my fabtec 2 inch level?
i had to zip tie part of the finder liner back other than that only a 1 inch piece of air damn rubbed at 3/4 turn but that was a easy fix good luck man
2015 Sierra Denali Crewcab 4X4
2-inch Fabtech Leveling Kit
20x9 Fuel Mavericks (+14 Offset)
305/55/20 Nitto Terra Grappler G2's
Stance = about 1-inch outside the fender
No Trimming. Slight rubbing on the inner fender was cured bu pulling the plastic back with zip ties. No rubbing at this point.
  • Like 4
Just bought some KMC XD Bully's 20x9 +18 wrapped in BFG KO2 275/60/20. No rubbing so far but I was putting a level on anyway. Next up, Readylift 2.25 inch level
Before:
After:
Edited by StayInYourLayne
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
hey bagged, do you think this wheel n tire set up would clear with a 2 inch fabtec level kit and a 1.5 inch zone body lift? thanks!
I've got a 2014 Silverado Z71 LTZ. Added the Rough Country 2.5" leveling kit, 20x9" Rockstar II wheels with a -12 offset, and 295/55 Toyo Open Counry M/T tires. Rubs a little at full lock right now, especially in reverse. I have aftermarket bumpers coming that should fix most of it, and will need to do a little trimming for the rubbing while in reverse. I'll try to take pics of the rubbing/trimming when I get some time. For now, here's a few pics of it in the shop (all I got for now) as well as some pics to show how much it sticks out with my setup.
Enjoy!
Where exactly does it rub?
This is exactly the setup I was looking at for mine.
I've been going back and forth between a 20x9 0 and a 20x9 -12 wheel.
The -12 wheel looks so much better than the 0 wheel but I don't want it to rub really bad.
I'll be anxious awaiting your detailed trim/rub pictures. :)
I should have these photos for you by Monday night. It's fairly cold here in MN, so I don't really want to mess with it til' I have time to swing into the shop :)
can you link me to the leveling kit you purchased please? I want to lift my truck and yours looks great to me. Very nicely done.
Thanks BootyHunter. Here is the link: http://www.fabtechmotorsports.com/LEVELING/C-K1500-2WD-4WD-2007-15/2-Leveling-System-2007-16-GM-C-K1500-2007-15-GM-C-K1500-SUV-SUT-2WD-4WD-p1504.html
Make sure to post some pics once you get it installed.
Will do. I have a couple of questions. Did your ride suffer at all? Or is it still Denali smooth? I leveled my truck from the rear (6 inch drop) with shackles and by removing the leaf spring blocks and I feel it rides kinda crappy. Like it's not Denali like lol
Sorry to bug but I wanna lift it a bit and add some bigger tires. These rubber bands I have are crap lol
The ride is pretty close to being like the stock ride. Not 100%, but close. I can feel the road more, but I think it's due to to the tires rather then the leveling kit.
The shop did have to adjust the magnetic ride sensors to accommodate the level.
I was also really concerned with how the ride would be after the level, but I'm really happy how it turned out.
Edited by SC_Mike
can you take pic of your tires in the more light. I'm thinking of getting the same tires. Do you like them
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 381 Guests (See full list)
