Shocker....Traded a member for wheels/tires.
2015 Sierra 1500 4WD
2.5" Leveling Kit
1.5" Zone Body Lift
OEM 22x9 +24 CK158 Wheels
325/50R22 Nitto Trail Grappler MT
No Trimming / No Rubbing
I also have a set of Nitto Terra Grapplers 285/55R22 and I'm on the fence about what setup I'll run, but here it is for now with the Trails
E2087E2F-F960-43A1-92C6-EB6354522A06_zps
  • Like 6
2.5" Leveling Kit
1.5" Zone Body Lift
I think it looks great!!
Got my 24X14 American Force Burnout with 37" Toyos put on today 3f6e67b09d0f7d34f84d09511fe693e7.jpga62c38797bef804adb425d4222abcfd4.jpg7d117eb85af6b74d274d5fe78f62e23e.jpg
Edited by Clint D
  • Like 9
Looks good!! What's the offset of the wheels?
thanks bro, and I think they are -44, plus I have 2" adapters
Edited by Clint D
Fuel Coupler 20x9 +1 offset
(On factory 275/55/R20 until my truck is lifted and i can fit 35x12.5's)
I actually like the way it looks with the OEM tires. Gives it a "street truck" look which i have no problem staying with until i can get it lifted.
They stick out maybe 1" from the fender, perfect look IMO, I love them!
22x10 Fuel Nutz
35x12.5 Toyo MTs
Love this setup! I prefer 22"s myself. Wish i could run a 35 on my 22" setup but i need more lift than just a level. I managed to cram 33.3" with my level tho. What lift are you running andis yours 4wd?
Thanks! I love the 22's. Would have gone 24 but you can't get 35's with a 24. At least not an MT. I've got the RC 6" but added Bilstein shocks and struts. Yeah it's 4x4 - notice the chrome decal on the fender [emoji39]
Yea im looking at it on my phone and missed the 4x4 sticker on small screen lol. Mine is only 2wd, as itll never see anything but asphalt but i still love the look. Thats why i went with a nitto ATs as i think in my case, its a happy medium. But yea man, i dig that truck. Looks killer
So the Bilistein shocks and struts is an "upgrade" with that kit? Do you find the ride similar to stock? Love those 22's, very nice look.
Sent from my iPhone
Sent from my iPhone
Absolutely. The RC rear shocks are not very good and since the truck has a lot of miles I decided to do the struts too. I think it rides better than stock. Even had a friend ride with me and he thought it rides better than my Infiniti. Thanks! I think the 22's are great.
2.5" Leveling Kit
1.5" Zone Body Lift
Looks amazing. Can you take some pics at full lock? I can't imagine this doesn't rub the sway bar at full lock, but if it dosen't you just gave me new hope for running the 325/50/22 Toyo AT2s on stock 22s.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 253 Guests (See full list)
