295/55R20 Trail Grapplers
The cure for any squeak, Rattle or any annoying sound your truck previously made. Even the steering wheel clicking... Gone! And it looks badass :)
Sarosi6671 Sorry I'm new to the forum n not sure how to put your quote into my message, and haven't found any other posts with info on your set up,but what I was wondering is if you had to do any trimming, or if the wheels n tires fit without rubbing? I have a 2 inch fabtech leveling kit, and that is the same offset and close to the same wheel I'm looking for. Also, do u have any more pictures of the truck, maybe down the side showing how much the tires stick out? Thanks, sweet looking truck!
Edited by levi59912
Shocker....Traded a member for wheels/tires.
2015 Sierra 1500 4WD
2.5" Leveling Kit
1.5" Zone Body Lift
OEM 22x9 +24 CK158 Wheels
325/50R22 Nitto Trail Grappler MT
No Trimming / No Rubbing
I also have a set of Nitto Terra Grapplers 285/55R22 and I'm on the fence about what setup I'll run, but here it is for now with the Trails
E2087E2F-F960-43A1-92C6-EB6354522A06_zps
What's on your mirror? I looks like you paper mache'd the light on it…
Looks amazing. Can you take some pics at full lock? I can't imagine this doesn't rub the sway bar at full lock, but if it dosen't you just gave me new hope for running the 325/50/22 Toyo AT2s on stock 22s.
I love this truck. It's my favorite look and set up. I'm looking for the wheel too. If you don't want the 285/55/22 terra's. Let me know. I have a '14 SLT CC SB WHITE 4X4 with 2.5 level. I really love this look. Great job.
I'll try to get some full lock pics for you today...
It's white vinyl lol I had removed the LED lights to mess with them and didn't want dirt / rain getting in there so I put white vinyl over it
I will probably be selling the Terras, thinking about keeping the 35 Trails... If you're local (DFW, TX) and interested in the 285/55/22 Terras let me know
No I'm not local I'm in Denver. I'll be getting a 1.5 body also. Will the 285/55/22 fit with out rubbing and what gears do you have. Will I lose any HP Going from 20" wheels to 22"/34" tires with 3.42 gears. Thanks
06CE8278-BB94-4A47-B88C-A039DE82AE5E_zps
4A085EEC-8B8E-4494-9A11-CEEE19E6D65F_zps
Hey Bagged I like the GMC over the silverado you had before. It looks like you have the amp power steps on your truck with the 1.5" body lift. If you do what was done for them to clear the center body mount bracket when they fold up. I have the zone 1.5" body lift on order right now but wasn't sure the best way to get the power steps to clear the mount. Would you mind snapping a pic thanks for any help.
You have to remove the bolt / washer and trim for clearance. I never did this on my Silverado and annoyed my so bad, so I finally investigated it on the Sierra and fixed the issue. Keep the cut parallel to the body and as close to that bolt as allowed to still function.
4885D72C-A0A2-492D-B3BF-ADF534C045A4_zps
Wow it really clears them that well? Any trimming at all?
How could I trim the sway bar? Lol I haven't done any flexed full lock instigation but everyday driving I haven't had any issue Edited by baggedlvintegra
I figured it took some trimming but that looks like more than a trim. My understanding is that the hellwig front sway bar will get you some extra clearance, I personally don't have a sway bar on mine, seeing the 35 inch tires on your's I think 305 65 18 should clear on mine no problem. I'm running -12 bs with 285 65 18 and they rub at full lock in reverse so the 305 have me a little leary. Thanks for the pic
Winter combo
Stock Denali 20"alloy rims with BF Goodrich KO2 275/550/20
Damn near the same circumference as my 295/45/22, so I don't have to change any speedometer setting.
Summer combo
Denali,
Winter combo
Summer combo
Denali,
275/70r18 Cooper Zeon LTZ
Bilstein 5100 shocks with 1 1/4" lift at front
Edited by MIameow
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
