2015 Sierra 1500 4WD
2.5" Leveling Kit
1.5" Zone Body Lift
22x12 Hostile Switcheblades ( -44 Offset )
305/40R22 Cooper Zeon LTZ
Slight Rub at full lock in reverse - Normal driving has no rubbing
B797A8CA-D576-4FB5-AF40-2DCEF93CA81A_zps
F4059979-9F76-4680-BA51-B79661F893AA_zps
Love it man, turned out great. Your truck makes me want tow's so bad tbh.
Nitto Terra Grappler G2 295/60/r20 with 2.5 RC level
  • Like 3
You sure about that size? That's almost 34" tires with just an 2.5 level? pretty awesome-blossom if you ask me!
Just installed my 2.5" Rough Country Kit, with the block in the rear...also added BFG KO2's, 275/65-r20 on the factory wheels
295/60/r20 NItto terra grappler g2.
Love my G2 graps too! Just curious why you chose that sidewall?
I liked both designs but i really didn't have a preference as to which was going to be seen. As long as all 4 were the same lol
i Gotcha. Im running the opposite "lightning Bolts" vs "Axe Heads". :cheers:
2.5 Leveling kit, 3" rear Blocks, 20x9 BMF Novakanes 0 offset, 295/55R20 Nitto Trail Grapplers, No rub, Global QDP Ceramic18% Tint, Amp Research Powersteps
Edited by LivNLo94
  • Like 10
Chillin
Sent from my SM-G900W8 using Tapatalk
Are those KO2s? Will you run them all winter
I have them too but just put on my real snow tires. I do lots of highway driving through the hills where it gets icey and didn't know if they could handle that. They seemed fine in the snow though
I will definitely be running them all winter they are awesome mine are 285/65/18 and we got about a foot of snow then icey rain and these baby's handled great... Didn't slide around didn't loose traction much just gripped and went so im not worried at all also took them threw some mud and they were great for me 42097b9907312b89de8fc244d0fa5ea4.jpg
Good looking truck and nice wheels. The 305/45/22 is 32.8 in diameter and the 285/45/22 is 32.2. That's about 9/16" total O.D. and only about 1/4" on sidewall height. I don't see how 1/4" would be too short for your liking or even noticeable by just looking at the tire. The 305 is a bit wider with a 12" tread width compared to 9.5" tread width on the 285. I think the 305 is a little too wide for factory 9" wheels on a stock suspension and is why they rub. The 305 is designed for a 10" rim and will give the "balloon" look on a 9" rim. I'd stick with the 285. I have similar wheels (CK159) instead of your CK158. I'm running Cooper Discoverer SRX 285/45/22. They fit the 9" wheels perfect, were road force balanced and ride
Good info to know but those wheels are 7 spoke not the CK158 wheels
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
