Thanks for the input, I might just go with the bigger tire and see how it works out. I have a friend with a 14 Silverado and he has 20x12 -44 offset with 285/55r20 trail grapplers and he just did the plastic mud flap trimming. I would assume I could fit a larger tire on a more narrow rim but I guess we will find out
I don't know if this is the right place to ask! :)
I bought factory 17" wheels like this:
https://lh3.googleusercontent.com/vOT1pLekKHYLlJMfc0vtxnMzzLCVtIFEPanwDGGandr4XkgePmyIlorE_lDrA023i3jnSQCgsVqKEwcjscK6eTAvmM2J2RTcAtvk8Q6JX_JqY0NDxK0biDWYh8tKwmSsd5TP9f1Mn47NJfCRm0C-NNRRFOZ7jYGca9MoiKGFv6DDWkFTXkFRAdB558oe7ZU0rEqts14-lnfeICBoepsrwmIurqM_Upv9jz9I2r02v6nQqdyegH96pIow_VNjyzl_z6jJ1mtr0qj76oveGuO-THGkb9RXzVU7KgGEfF106zLZaTA59ZrMzba7L2qKAKR2JoPL_isUg1zLOI6iOUKUCHJ_Vyqev0lrIS18UYLBzX8qHL_jQlfEWK8mG88S9ee1zlk8Nl5hJGOZP4trQGyViXd0d4MpB5lwhW_ZnweYHe3u4kNXnefeHzDnAU7PdKWyP-4qQL1hqoOZ3IYLEf7bX8EKrPgaMYkdLIju2k4We45H8ayECtxeYJdqQpgbT1SPBbn2Z9M7vOQUVpiYPxEZ8h2Hsogy0j9MMqS78XSDa3EqDPWMVLaZ_sheL3Yr1jAalxUG=w694-h360-no
and I can't decide which tire is the best for this kind of wheels and stock factory lift 2016 silverado! I'm looking for a quiet ride, low noise, good for sand dunes!
here is the list:
1- Yokohama Geolander A/T-S 285/65R17 116H (H = 210km/h) has more aggressive pattern and can reach 210km/h but little bit smaller
2- Toyo Open Country H/T 285/70R17 117T (T= 190km/h) has best tread life and lives very long
3- Firestone A/T 285/70R17 117T has best price with A/T pattern too
any thoughts, opinions?
guys what tire/rim size you reccomend for a 5" lift on a 2014 silverado? front fender measurement is 40" & rear is 41" 1/2
Edited by Suspension
Cooper ATPs 275/60/20 on stock AT Black Rims
Sent from my SAMSUNG-SM-N900A using Tapatalk
Nice rims!
Ryan
Here is mine. 20" Stock High Country rims with 325/60R20 BFG ATs.
  • Like 4
I have posted on here before when I just had the leveling kit installed, not sure if I have posted since I installed RCX 5". Also added .5 Lower strut tgc spacer, total 5.5" of lift. I am running a 20x10 -12 fuel Mav. with Nitto trails. Do you guys think I could run a 295/60 with lift setup?? I am thinking of going to the Toyo AT II's also. Thanks in advance! post-136138-0-64762300-1453912322_thumb.jpeg
Is anyone running hub-centric rings with aftermarket wheels? I'd love to find a set for my Methods.
Mine came with the wheels from BMF, no the tire shop didn't put them on and used the lug nuts that are supposed to align them, I have no vibration but I plan to rotate the wheels and put them on for security.
Finally was able to install my new wheels and tires.
305/55/20 Toyo AT2 Xtreme with XD Bully Matte Gray +18
2.25 inch Readylift level with 2 inch rear blocks. Not one bit of rubbing.
20160127 103747 1
20160127 103736
Edited by buckeye6
What's the set up? Looks really good! Any trimming or rubbing?
The lift is a 6in RCX with the BFGs and stock rims. Never trimmed and no rubbing even with no offset. The The Amp Research running board really give it a clean look.
I have read a lot of people saying that RCX is not a high quality lift but I'm on my third one and my Father is on his third and neither one of us has had any problem.
2.5" Level + 1.5" Body Lift
20x10 ET -24 Moto Metal MO970
33x12.50R20 Federal Couragia M/Ts
No Rubbing / No Trimming
Great setup man! Im wondering about a similar setup if you dont mind giving me your input? Its for a 2014 Silverado LTZ 4x4
2.5" Front & 1.0" Rear lift
20"x9 Fuel Offroad Nutz +1 offset
305/55 32 x12.50 Cooper Discoverer STT Pro
Do you think compromising with the offset between this setup and yours and the 20"x9 instead of the 20"x10 allow me to fit without the 1.5" body lift with little to no trimming?
Ive heard different things and I know its hard to tell until its on the truck, but any input would be appreciated! Thanks!
Gotta a question for you if you dont mind?
I like your setup. Im thinking about something very similar. Do you think there would be any issues with a 2.5" Front & 1.0" Rear lift and putting 305/55/20 +1 offset? How much clearance do you have currently? Does it rub in 4 wheel drive any? Im not against trimming but id prefer not to. Thanks!
Traded my stock rims for 20x10 fuel maverick last night. Only pic I have so far. Sitting on stock tires for now. Going to get some new tires soon.
  • Like 4
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
