Hmm, they're either balanced incorrectly or they weren't torqued down correctly. The pattern in my aftermarket wheel manual states to torque them down to 100 and then to 140 in the following patter (think clock). 12-6-2-8-4-10. Might give that a try. I had to mess with mine a little before they seated correctly but your balance or road force could be off.
Well I'll give that a shot. 2 of the tire shops said I should probably just get new tires based on the wear, but I'd rather not buy any yet. The tires were smooth as silk going down the highway before I switched rims. Could it be that because these are a little wider they will just vibrate due to wear? Maybe it is the tires.
I have posted on here before when I just had the leveling kit installed, not sure if I have posted since I installed RCX 5". Also added .5 Lower strut tgc spacer, total 5.5" of lift. I am running a 20x10 -12 fuel Mav. with Nitto trails. Do you guys think I could run a 295/60 with lift setup?? I am thinking of going to the Toyo AT II's also. Thanks in advance! attachicon.gifimage.jpeg
http://www.gm-trucks.com/forums/topic/161228-post-your-2014-wheeltire-set-up/?view=findpost&p=1689890
im running a cooper stt pro 295/60/20 with only a level. so you should be fine
Well I took the truck to discount tire this morning instead of the 3 different NTB's I've taken it to look at this. DT took a little bit of weight off and moved the weights to the inside lip of the wheels. Originally they were on the outside edge of the inner wheel. My problem seems to be solved. No vibrations driving into work this morning!
  • Like 4
Awesome! Good to hear you got it taken care of
Sent from my VS986 using Tapatalk
Edited by Dbotello1983
Me too man! I was pretty disappointed at first when I left NTB friday. I got a lot of vibrations when I got on the belway. Figured it was a simple balancing issue, so 2 more trips to NTB and a trip to DT got it taken care of lol. Anyway, hope your buddy is loving the rims the same way I'm loving these!
What is NTB? Discount tire has been great with me, my k02s on my old F150 came from their and they had excellent service! Have treated the wife really well there too, no absurd up selling like our local GM dealer.
Edited by jrob56
National Tire and Battery
I usually use Discount tire for all of my wheel/tire needs. At the time I got my rims over the weekend, NTB was closer so I unfortunately went that route.
Have had a few stages of mine:
2.5" Level
22x9 ET 31 GM CK375
285/50R22 Nitto Terra Grapplers
No Rubbing / No Trimming
20140309_181408_RichtoneHDR_zpshpzrn76q.
20140309_163922_RichtoneHDR_zpssc3pelut.
2.5" Level + 1.5" Body Lift
22x9 ET 31 GM CK375
1.5" Wheel Spacers
20140410_171128_RichtoneHDR2_zps23f8ff92
20140321_172117_RichtoneHDR_zpskneqfo8m.
20x10 ET -25 Ultra Lightning
33x12.50R20 Federal Couragia M/Ts
20140505_194936_RichtoneHDR_zpsf7uu5eer.
Coming Soon...
3.5" "Lift" + 1.5" Body Lift
20x12 ET -44 TBD
HOPEFULLY No Rubbing / No Trimming
Very nice
Got my new wheels mounted today. [emoji7]7e6bf1ff1f51aafa734660bb3111412f.jpg19d4f4ed7f4de44d5269d7cdd86beccd.jpg8769525fa408af7a131f6a85b36130fe.jpg
Concavo CW6
26 inch gloss black.
[emoji41][emoji6][emoji7]
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
