Got my new wheels mounted today. [emoji7]7e6bf1ff1f51aafa734660bb3111412f.jpg19d4f4ed7f4de44d5269d7cdd86beccd.jpg8769525fa408af7a131f6a85b36130fe.jpg
Concavo CW6
26 inch gloss black.
[emoji41][emoji6][emoji7]
Love your setup. I just wish i had the balls to run a 26". Too scared that the wife (or me for thatmatter) would curb check or pithole split em. Howa the ride with those rubber bands?
surprisingly smooth with the magnetic ride on the denali.
and I believe this is the biggest tire for 26 available (low profile)
305/30/26
I'd divorce the wife and run the 26's :D
Traded my stock rims for 20x10 fuel maverick last night. Only pic I have so far. Sitting on stock tires for now. Going to get some new tires soon. 43e2ad4544b0396f8388e9a15a2281c3.jpg9932e86feb6c33bf541e9e02de46daa0.jpg
Are those on a -12mm or -24mm offset? Any rubbing/clearance issues? I currently have 2.5 RC level w/ rear block. Looking to run a 20x10 on -24mm offset XD820 wheel. Eventually will go to a bigger tire but the stockers only have ~11k miles so I'd hate to waste those. Also, do you have any pics down the side of the truck? Would like to see how the stance looks with the stock tires. Thanks man!
Here are some pics for you. Wheels are -24 and I've got no rubbing on stock tires. Once I throw some 33's on there there should only be slight rub on sway bar on full lock.
Can I fit some 275/65/20 on a 2016 AT with only a bilstein level kit?
If you have it on the max setting you might get a slight rub.
GF has 275/60/20s on a 2 level absolutely no rubbing
I have 305/55/20s with the same level and mine rub a bit but i love the look so i live with the rub.
Sent from my Note 4 on Tapashit
Here are some pics for you. Wheels are -24 and I've got no rubbing on stock tires. Once I throw some 33's on there there should only be slight rub on sway bar on full lock. 1e5817272bd47648a0abcd50c504a767.jpg9135a2b369e5bf10088bd3f0ebf153b4.jpg
Appreciate it man!! Truck looks awesome with the setup. Yea as far as the tire size goes, I've been back and forth between 33x12.50, 305/50/r20, and 295/55/r20. Look forward to seein the truck with the 33s on it.
Thanks man. I love them on the truck. These stockers will be worn out pretty soon so I should have some new pics with tires mounted in the near future. I would consider a 295/60, but the RT's are only offered in 33x12.5
Good looking truck. I have a 2015 crew cab with a leveling kit and I am running 20x10 -24 offset wheels and 33x12.50x20 Toyo R/T's and it rubbed pretty bad. It's manageable to drive around town but you need to be cautious of it. I eventually had to put a Fabtech 4" on the truck. Here are some pics before the 4" kit.
Thanks for the heads up. Where were you rubbing? Sway bar, inner fender liner? Also what leveling kit do you have?
I was running the ready lift 2.25" and it was rubbing on the inner fender basically where the fender liner bolts to the bottom of the fender. I probably could have trimmed a few things but I really didn't want to cut up a new truck. My other option was to put the zone 1.5" body lift on but the shop that I go to doesn't care to do them and charges a little more for the labor, lol. I know every truck is different but I just thought I would share my experience with you. By the way the Toyo R/T's are great tires. Hardly any road noise and they look great.
Sweet!
No matter how many black trucks I see. They are still beautiful
sent from Florida beech
Thanks for the info man. I've got a 2.5 on mine up front so hopefully that will clear the fender. The guy I got these wheels from had a set of RT's on his truck and I'd been on the fence about them until I saw them in person. He had nothing but good things to day about them as well.
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 381 Guests (See full list)
