Loss of power
Dj0nes
I haven't been to the dealer since I got the tune, so it should be good. Really seems like a bad sensor or something. It's like the computer is seeing something that isn't there and in turn causes the trans to shift poorly and the engine to not be as smooth. Almost like the throttle sensor is bad or something. It's a problem that is gonna take some digging and unfortunately my dealer is not willing to do that. So I'll probably just drive it until something breaks.
  • Replies 47
Could this be bad gas? Or a clogged fuel filter? DI engines run at a much higher fuel pressure, so a drop in pressure could cause something like this. Is fuel pressure monitored by the PCM to throw a code? Usually not. MAF problems usually throw a code as its performance is monitored.
The weird thing is that when I noticed the loss of power my MPG went up from 15 to 18. I have been driving around for the last few days with traction control off and the loss of power seems to be gone and the MPG is back to 15.
Are you taling about when you floor the throttle and the tires spin? Because that will cause the traction control to cut the fuel to the engine to slow you down.
I also thought it could be fuel pressure related. There was a TSB out for it. I took it to the dealer and asked them to check fuel pressure. Was told "no codes" - their favorite line.
? Who said anything about flooring the throttle and spinning the tires
I think it's AFM or fuel related. The problem is without a trouble code the dealership won't do anything.
Sometimes it stays in V4 and 6th gear too long and gets bogged down and then realizes "oh shit" I'm still in V4 and "damn" I should have down shifted.
Guess I spoke to quick, loss of power is back and traction control has no effect on it. I noticed that when I experience the loss of power I also get a whining noise when I let off the gas or slow down.
  • 3 weeks later...
I have been noticing that sometimes my front rims get very hot and the backs stay fairly cool. Even on short drives. I was thinking that maybe the brakes weren't releasing all the way causing my loss of power.
Took it to 2 different dealership and was told that they couldn't duplicate it and that it's operating normal.
Well yesterday my check engine light came on and the front brakes locked up at a traffic light. I was barely able to get it to a parking lot, the front rims were soo hot you couldn't hold your hand on them, the backs were cold. I waited awhile and then was able to drive home.
Do your front rims get excessively hot and the backs stay fairly cool? Maybe this is causing the loss of power.
I have an appt tomorrow, hopefully they will find it.
Yep, brakes are dragging.
Brakes were dragging, numerous fault codes, ABS, Traction control/stabiltrack, power brakes, power steering, etc.... At first they thought it was faulty wiring but that wasn't the case. They cleared the fault codes/check engine light and it seems to be gone. They told me to put some miles on it and if it doesn't return they still would like me provide feedback.
Definitely has more power now and front brakes are cooler, hopefully it doesn't come back.
Yea, whatever, front brakes are dragging again, back to the dealer.
that's crazy.... make sure whenever they fix the problem to replace your brake pads and rotors as the excessive heat from the brakes dragging more that likely put some heat spots in your rotors. at least now the problem is recognized and hopefully the problem will be solved and behind you. a faulty sensor is more than likely going to be the blame.
Yea, now the dealer tells me it's normal because none of the codes came back. Ok the code didn't come back but the condition is still there so how can that be normal.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
