PF63-PF48 Interchangability
The only reason I would now is the Hastings PF63 filter equivalent is more efficient than the PF48. Take a look at that table. I've ordered both of the Hastings filters (PF48 and PF63 equivalent) to cut open just for hahas. However, as I have mentioned previously, whichever way I choose to go it may well be a Hastings just because they are so responsive to their customers. For a representative of a corporation to say: "It is our practice to recommend the use of our products as they are listed by application. Nonetheless, as these filters are made today, the LF641 will offer a slightly better efficiency if used in place of the LF613" is an absolute breath of fresh air. That and including that table sold me. Here is a company that deals exclusively with filtration, and it shows.
Would appreciate ALL comments both pro and con.
I am thinking about going to the PF63 on my 2013 Yukon Denali.
The dealer tells me, "as long as it is a AC Delco oil filter, it will not void the factory warranty"
Thanks in advance.
Please look through this search.
https://www.google.com/search?q=pf48+vs+pf63+oil+filter&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb#channel=sb&q=pf48+pf63+oil+filter+site:www.gm-trucks.com&rls=org.mozilla:en-US:official
PF63
Product Type Full-Flow Lube Spin-on
Anti-Drain Valve YES
Gasket I.D. 2.45"
Gasket O.D. 2.76"
Gasket Usage Base
Product Height 4.06"
Product I.D. 22mmx1.5mm Th'd
Product O.D. 2.98"
Relief Valve Setting PSI 9-15
PF48
Gasket I.D. 2.45"
Gasket O.D. 2.76"
Gasket Thickness .19"
Gasket Usage Base
Product Height 3.33"
Product O.D. 3"
Relief Valve Setting PSI 9-12
AC Delco has nothing to do with it. Dealer cannot disavow warranty if using another brand. That is quite clear at the Federal Trade Commission who enforces the Magnussen/Moss Warranty Act. The only way for them to have any standing in voiding a warranty if you use alternative brand is if they can prove that it in fact caused a problem. Amazing that this warranty act has been law for 40 years and some nincompoop at a dealership still thinks they can set the standard.
