the first person to get an Edelbrock SC on a 6.2!
No. There's lots of info there. Maybe when you get the SC on and have results/review to report you should start a new thread for that to be discussed.
We'll still remember what numbers it's gonna make lol
  • Replies 262
Well if anyone wants to know what a stock 6.2 does on the dyno here you go!
The blue lines are 3rd gear and the red is 4th gear
personally I am quite impressed, these numbers aren't far off from what LPE got with their SC 5.3
I can only imagine what the final result will be. if they are able to do 100+ hp and tq that should put me over 500 to the wheels!
If that's what it's really puttin down to the wheel, that's impressive. Too bad you can't go do 10 runs down a track as well! Then compare after!
I was told the truck is on the lift as we speak getting the pacemaker installed..
I can confirm that the battery is disconnected as I can no longer get updates on my OnStar application. but I know they put 26 miles on the truck on the dyno since I dropped it off and used 10% of the fuel in the tank.
lol
I've seen multiple graphs from new 6.2's that put 330-340 down. Is yours stock but tuned?
400 at the wheel in a truck that makes just over that at the flywheel? Wonder what the correction factors are set at on that dyno?
Either way, interested in a before/after number anyways. And a 1/4 mile time
dude, im as clueless as you.. all I know is this is what they sent me. but this much I do know and you can take it with a grain of salt because its pure speculation on my part.
I do know for a fact confirmed by 2 different sources the only difference between the 6.2 in the truck and the stingray is the intake manifold and the tune. I find it interesting the stingray makes I think 450 something hp and tq the truck 420 and 460.
I find it hard to believe the stock flywheel HP is down that much on the truck but also consider that the trucks redline is 6,000 and HP is calculated as rpm times TQ divided by 5252.
this means any engine that makes more peak torque (or can maintain a sufficient amount of tq) above 5252 will have more hp than tq any engine that makes peak tq below 5252 will have more tq than hp.
if you look at the graph you can see this engine is making more TQ below 5252 as such it is obvious why the TQ is greater than HP it explains why the stock specs are 460 tq and to have 400 TQ at the wheel is about a 15% drivetrain loss and exactly what I would expect.
personally, I think manufacturers like to publish HP numbers because often times the HP is more than the TQ (it looks better on paper to a consumer) but when your talking trucks we really need to be looking at the TQ numbers because that really tells the whole story about how much pulling power it has.
after all HP is a calculated number, and it is representative of the work being done and is a good benchmark to calculate 1/4 mile times. but in reality it is the TQ and how long the TQ curve stays constant that really indicates the twisting force that you feel at the pavement.
having said all of that, I believe the transmission and the lack of a perfect 1:1 gear ratio will skew the results. clearly the 3rd gear run and the 4th gear run are different on this graph. it seems to be the taller gearing shifts everything up in the rpm band and also the curve itself is different. so I think its fair to say without getting into a technical mathematical answer as to why this is I think the gear ratio changes the actual output and also skews the peaks to different RPM's
also since 5252 is only 750 rpm away from redline, HP really becomes irrelevant in a truck. (Which is why you almost never see it advertised on a diesel)
so with that said unlike most dyno graphs your used to seeing I will focus more on the TQ curve and improvements found there and I am also willing to bet the transmission will shift before 6k leaving the HP numbers pretty much useless.
besides GM even rates the peak TQ at 4100 rpm and the peak HP at 5600rpm looking at the graph and keeping in mind the gear ratio changes the peaks they are both pretty consistent peaking at those rpm's 4600 for the tq and 5900 for the hp
and again I am by no means an expert but I think the TQ curve and how long it stays consistent tells a much better story as to how the power comes on, stays strong throughout the usable rpm range.
LPE's 5.3 SC made 416hp and 444 tq with 6 lbs a 105 improvement over stock. another example of a truck that makes more TQ than HP
also I don't know about LPE but edelbrock told me today on the phone that their published numbers are lower than they actually got on the dyno. they do that because if someone buys their kit they don't need to hear someone complain about how they didn't get the same results as advertised. so with that said im going to ignore whatever they publish and instead use the actual dyno numbers used in my install and tune after this is all said and done.
if anyone has a better answer to share I am all ears. I agree the HP looks high but this is the best answer I can come up with.
looking at the graph I can see why the truck tows so well like all trucks the meat of the tq is right in the butter zone between 4000-5500 (adjusting for the skew of 3rd gear) that's right where your engine will be running going up a hill in a lower gear.
Also a quick peek at what I have waiting for my truck when it gets home, BLACK CHROME wheels. I've also decided to change out all the chrome door handles, mirror caps and side moldings for black chrome as well. I think on a black all terrain truck with a sc will make for a very cool visual and performance package
for those following, i got an update today, the intake manifold is off, and the supercharger is being assembled. i don't know if that means the actual supercharger is being assembled or if that means its still being fitted to the truck, i suspect the latter because it only takes about 10 minutes to assemble one.
they say the wire harness is installed. now sure what harness that might be except the electric pump that pumps the water through the intercooler / heat exchanger.
the problem is this week the head tuner technician and the lead sales guy I've been talking to are both on vacation.
one of them returns tuesday that will be able to give me a better update.
also they have a few other projects they are working on and short of staff this week. so ill keep waiting and trying to be patient! anyone who knows me would tell you patience is definitely not one of my strong points..
Are u sure the blue is 3rd and red 4th? 4th is closer to a 1-1 ratio and would show as much, if not more power than a 3rd gear pull. Really doesn't matter, impressive numbers... Just odd.
I see they added vents on the top cover. I know there was heat issues with the eforce. I bet this alleviates that problem.
I wondered the same thing.. But yeah still strong numbers!
I knew somebody else with Dyno experience would catch it.... not only is it lower, it's a different curve.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
