I pulled my project truck around to the front of the house
Need to get it washed. Damned bugs....
Spray a little spray wax on the front bumper after every wash. Takes 30 seconds but the bugs come off very easy.
PM sent.
I use detail spray for that. Works good, and gets rid of the water spots. Right now it needs hit with the lay bar...bad, but I'm not up to that yet. Too much stretching. Maybe in a few weeks.
Used to have an 89 formula, but it went to my younger bro when I got the truck and then was sold. Dad has a 94 z28 vert. Love driving that thing when I go home to visit. Cant wait until I can get a muscle car again.
Edited by cobrajet84
DON'T drive a 5th gen Camaro unless you brought your checkbook. You'll fall in love.
Fix it Friday
Ryan
OW!
Looks like there's more than a few of us with GM sports cars on here!
Best part they fixed for free. Also got my butterfly valves welded open for free today
Have you guys seen the video of the Z/28 that crashed? I got to see it today. It was at Bruce Raymond's shop. Pretty awful shape :( mike Norris had a yellow 1LE out front.
Ryan
haven't driven one, have sat in one and oogled over, lol. Waiting for the checkbook to eventually meet the level of the love, lol.
Ryan
Saw that z/28 crash, i may have teared up a little, but at least it was on a track and not on the road. I love the 1LE's.
It didn't look to bad in the video and photos but let me tell you in person it looks awful :(. I couldn't bear to take a photo.
Ryan
well, I took My Little Aveo to the Dealer yesterday to make a Check Engine Light Go Away, then found out 2 hours later they got sent the wrong part, which I had to take it back today, had the correct part installed, and then got the Typical Dealership monetary raping to the tune of $544 for a SINGLE SENSOR.
Freaking Painless wiring is giving me a pain in the butt. That's why my LED tails don't work, turns out it's extremely common for Painless to wire the flashers backwards. It only turns up when your using LEDs and no load flashers, which are very sensitive to that.
GM's offering 0% for 72mos....http://www.chevrolet.com
Sounds like I should skip buying their product then if I ever need anything.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
