I have to agree... I sweat bullets every time I take this out of the garage! :lol::uhoh:
Cannot imagine. You really have to know where you are going. Inclines off of main streets. Even some of these stores throw out those speed bumps across their parking lots can make things interesting.
Just transported this out of Daytona Beach, FL to Indianapolis. I do open transport, but this should have went enclosed on a trailer that had a lift gate. Dropped my air bags & used a couple of boards trying to get the front end to lift up enough to clear the ramps. It worked, but was paranoid as can be.
Where in indy?
Ryan
Most cars back over better than go forward. My older car is really low. Leaving my cousin's wedding, I pulled into the spot closest to the road and waited for an opening. Watch a new Porsche drag it's front and then I backed out just like I pulled in to the church. No scrape and applause from the groups standing around.
Installed last of the ARP bolts that showed up today to hold the tranny to the bellhousing. Also installed and bleed the McLeod clutch master.
More cup holder capacity
Ryan
Thought this was a cool picture so figured I'd share.
Sent from my iPhone 6+
Edited by Roidz
Nice!
I knew IMMEDIATELY after I sold mine, that it was a mistake!
I actually called the guy right after I sold it to him and offered him a $1000 profit after owning it for one day! He politely told me "No F-ing Way"... :lol:
Edited by Luster
Nice!
Very clean looking bird! My dad sort of did the same thing. He traded his in on a CtsV and tried going back to the dealer a few days later but they'd already sold it.
I had one about 6 or 7 years ago but had a lady run a red light and hit me and totaled it. I knew I had to get one again so I bought my current one last year. I'm very happy to have one again.
What do you drive? I can't see any clues in your sig...
Sunny tomorrow!
After ten inches of rain in 10 days we finally got a break and I can go to the cruise night for the first time in 3 weeks. Yaaaayyyy.
6th gen will be at the indy 500 this year and also camarofest in August :)
Ryan
Ryan
I'm looking forward to the reveal to see what the 6th gen is all about.
Saturday 4pm is the unveil it will be online
Ryan
Painted my steering wheel bow tie AGM tonight
Ryan
Leaked a day early
Ryan
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
